Old 02-15-2007, 08:41 AM   #1
brucy boy
Your Ride: 1995 bmw 316i
Angry Frustrating Problem
Hi there all im new heer, i have a 1995 bmw 316i for 2 years not one problem. The water pump got replaced as did the fan-belt tensioner and a cog. Now i have the problem of the fan belt ripping and comming off.
Any help with this issue will be greatly appreciated
Thanks Bruce
Old 02-15-2007, 09:08 AM   #2
Rate My Car: 84 / 337
Maybe the pulleys are not lined up and one is cutting the belt on its edge
Old 02-15-2007, 09:52 AM   #3
3050rpm
3050rpm's Avatar
Could you explain what you mean by having replaced a cog?
Old 02-15-2007, 11:06 AM   #4
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
i think cog=pulley/gear
Old 02-15-2007, 12:04 PM   #5
brucy boy
Thanx all for thanx all for the help the pulley was replaced at the fan side at the top. After the car runs for a few min it seems to run off the alternator then comes right off any ideas? thanx one again your assistance is much appreciated
Old 02-15-2007, 12:06 PM   #6
brucy boy
thanx for the reply, any suggestions on what to do?
Old 02-15-2007, 12:18 PM   #7
Rate My Car: 106 / 337
Did you check to see if the tensioner is working properly? I'm assuming you have the belt installed correctly?
Old 02-15-2007, 12:40 PM   #8
brucy boy
the tensioner was installed by a mechanic do u have to push the lever on the tensioner towards the drivers wing to put it on? why does it keep comming off the alternator? thanx
Old 02-15-2007, 12:41 PM   #9
brucy boy
you wouldnt happen to have a diagram of how the fan belt should look do u? thanx
Old 02-15-2007, 12:48 PM   #10
brucy boy
the mechanic put it on how can u check if its linned up properly? you dont have a diagram of what the fan belt should look like when on? your help is much appreciated.
Old 02-15-2007, 12:49 PM   #11
If the 316 is a 4 cylinder:
Old 02-15-2007, 01:06 PM   #12
brucy boy
thank you for your promp response. looking at the diagram my engine has 2 main cogs at the bottom then one on the fan belt the tensioners on the right side with another small one at the top then the alternator at the right side. im sorry for being dumb but car engines arent my thing any help appreciated thank you once again.
Old 02-15-2007, 01:34 PM   #13
Could be my mistake, the illustration showing is for a 318. I was assuming they might be the same.
Old 02-15-2007, 01:50 PM   #14
brucy boy
thanx anyway it is the 316i 1995 model if you could get me a diagram for that it would be much appreciated.
Old 02-16-2007, 11:41 AM   #15
Rate My Car: 137 / 337
go to www.realoem.com enter your info and they have great schematics
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 08:50 PM
E36 : anyone had this problem? akinthecat E36 6 09-28-2007 04:35 PM
528I gear problem, Please help me guys, plz plz djfactor E12, E28, E34, E39, E60 3 10-22-2006 05:56 PM
