Old 02-10-2007, 12:15 PM   #1
vIcKtOr9
Your Ride: 95 325i
fuel pump
does anyone know where the fuel pump relay is located on my car bmw 325i 95? When i turn the ignition on position2 the fuel pump doesnt make that noise and someone told me that the fuel pump might be bad but to first find out if the fuel pump relay was good before replacing the fuel pump need help please
Old 02-10-2007, 12:29 PM   #2
Rate My Car: 106 / 337
Old 02-10-2007, 02:45 PM   #3
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
Dude - that was a true quality DIY. Very well done, my friend.
When I was a kid, we had the Atari 2600 with games like Space Invaders and Asteroids! There were no multiple levels or screens, it was just one screen forever! And you could never win. The game just kept getting harder and harder and faster and faster until you died! .... Just like LIFE!
http://www.aftermarketcity.net/forum/
The BEST online directory for your car needs!
ユナイテドビーマーはいいですよ!
Old 03-05-2007, 01:12 AM   #4
mtm
Your Ride: e36 coupe M50
i had the same problem, in my case, the fuel pump was dead, but i also checked the relay, when you open the fuse box in the left top corner are section with 3 or 4 relay i dont remember quite well, the fuel pump relay is the third from the top.
The relay should have "click" sound then you turn the ignition on position 2.
also you can try to disconect the black conector from the fuel pump, he gives the power suply. Simply, conect the 12V bulb to this conectro and turn the ignition on position 2, if the bulb glows the electrical chain from engine to the fuel pump in ok. and the problem is in the pump
for detail info pm. good luck
Help With Fuel pump and no power!!! POS_BMW E36 7 11-27-2009 10:14 PM
fuel pump... mzbmw325i E21, E30 15 07-05-2009 06:16 AM
Fuel pump zeaq328i E36 12 04-28-2007 12:08 AM
