Old 02-15-2007, 07:39 PM   #31
quest6445
Rate My Car: 190 / 340
Your Ride: 1993 320is coupe, 1994 328is
The TPS has been orderd and I will check out the VANOS side as you mentioned, the car is not driving me batty as yet, its only a mechanical lump and i can't let it beat me.
That said after leaving the car over night and using one of my other toys I took the car out this afternoon and it drove perfectly for the 30 mile round trip. The only change is the weather, very wet.. electrical/air leak but not mechanical by the looks of things.
Old 02-16-2007, 09:20 AM   #32
3050rpm
3050rpm's Avatar
Well, maybe all this "talk therapy" had some effect...
Old 02-16-2007, 09:38 AM   #33
Rate My Car: 134 / 340
After reading some of the follow throughs, it's almost sounding like and electrical connection - like a ground(s) issue. For reasons:
a) wet weather - problem didn't seem to be present
b) when cold - problem wasn't as evident.
In both situations mentioned, cold or wet contact seems to be better. When warm electrical contact(s) expand. Start looking for coroded contacts on all electrical connections (green or exposed) Get yourself a small wire brush and start cleaning connections. Especially if car has such low mileage and has been sitting - I suspect you'll find your problem.
Old 02-17-2007, 12:37 AM   #34
daki77
Your Ride: '93. e36 325i (EURO)
Originally Posted by quest6445
BTW has anyone managed to get the errors code from the On board diagnostics. I have tried numerious times but no go.
Our cars (EURO spec.) don't have that. Only US spec do... We don't even have CEL's...
Old 03-26-2007, 01:50 PM   #35
quest6445
Problem solved... While taking the Vanos solenoid off to check I noticed that the pulse generator was loose and the breather pipe was letting in air. After tightening the pulse generator and installing a new o ring the problem has been resolved..
Old 03-26-2007, 01:50 PM   #36
Rate My Car: 84 / 340
Glad to hear it
