Old 02-08-2007, 03:08 PM   #1
V-tecKILLAH
V-tecKILLAH's Avatar
drivetrain related problem!!!
Okay my 325 after sitting down for nearly 2 years will be coming out soon. Heres the problem the car goes into gear perfectly when the car is not running..However when the car is running and i sink the clutch the car will not go into gear. . If I press the shifter against the gear it will try to move. Now If i leave the car in gear and try to start it, it will give a back and forth jerk.. My guess is maybe the cluth slave cylinder and proper bleeding, The clutch was good before I put it down and the gearbox must be good if its going into gear without it running.. Any thoughts guys??:
Old 02-08-2007, 05:17 PM   #2
Rate My Car: 137 / 337
sounds like condensation has gotten into the clutch slave -drain, flush and refill - look for leaks also
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 08:50 PM
E36 : anyone had this problem? akinthecat E36 6 09-28-2007 04:35 PM
528I gear problem, Please help me guys, plz plz djfactor E12, E28, E34, E39, E60 3 10-22-2006 05:56 PM
