Old 01-27-2007, 07:58 PM   #1
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
Brake Failure - 98 328i
Greetings gang. I bit of a conundrum here.
Whilst traveling, I left my auto at home with mum. She was using it one day and said the brakes failed her. As a result, she rolled into the intersection. She said they made a growling noise, as if the brakes were engaged half way and not stop the car. I asked her if it was possible that she had the brake partially pressed whilst remaining on the pedal (since BMW pedals are close and the accelerator swings out towards the bottom). She assured me that was not the case.
My old man gave it a once over while I was still away and said everything appeared to be fine - no abnormal wear on the pads, full fluid level, and since then it appears to be stopping quite fine. To my understanding, no check lights came on and it only happened on that one occurrance.
Thoughts/Ideas?
When I was a kid, we had the Atari 2600 with games like Space Invaders and Asteroids! There were no multiple levels or screens, it was just one screen forever! And you could never win. The game just kept getting harder and harder and faster and faster until you died! .... Just like LIFE!
http://www.aftermarketcity.net/forum/
The BEST online directory for your car needs!
ユナイテドビーマーはいいですよ!
Old 01-27-2007, 08:39 PM   #2
Rate My Car: 106 / 337
Originally Posted by CAPiTUL
She said they made a growling noise, as if the brakes were engaged half way and not stopping the car.
Heh . . . She must have hit something slick and set off the ABS. I'd say the description "growling noise" is a dead giveaway.
Old 01-27-2007, 10:21 PM   #3
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
Remedy ideas?
ユナイテドビーマーはいいですよ!
Old 01-27-2007, 10:27 PM   #4
Rate My Car: 84 / 337
If that is the case there is no need for a remedy. The sound is the ABS automatically letting off and re-braking on very slippery road surface. There would be no way to stop better with such little traction
Old 05-31-2007, 11:36 PM   #5
chizel
Your Ride: 2002
your brake system may be crying for help if you're hearing strange noises when you depress the brake. two of the most common are squeaks and grinding. check the linings and pads: the BMW brake pads and brake shoe linings should be checked periodically for uneven or excess wear, glazing, or saturation from brake fluid or grease...
Old 06-01-2007, 10:53 AM   #6
stevo
Your Ride: 1997 318se Touring
Remedy ideas?
yep, don't let your mom drive your car
Brake Light Failure eavery19 E36 14 09-09-2011 08:30 AM
Emergency Brake Failure dinan540 E12, E28, E34, E39, E60 14 11-15-2006 08:00 AM
'98 328i CAPiTUL Bimmer Showroom 23 04-30-2006 04:55 PM
WTB: E36 rear springs for 98 328i ASAP!! ivopivo Bmw Cars For Sale/Wanted 4 10-11-2005 10:46 PM
my new '98 328i DEATH2000 Bimmer Showroom 4 05-11-2005 02:02 AM
