Old 01-20-2007, 01:26 PM   #1
thorntoncg
Your Ride: 1993 BMW 325i
Electric Window will not lift
Motor is running when activated but driver glass does not raise. Any DIY's for removing door panel and inspecting?
Old 01-20-2007, 01:43 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Somone should be able to help with this issue, i think its something to do with the window track.
Old 01-20-2007, 03:33 PM   #3
Rate My Car: 183 / 337
yea its probably the arm or the track is not connected to the motor, you may have a broken plastic clip, those are very common, for an e36, you unscrew the screws near the door handle, both the one you pull on and the one u open the door with, and then i think maybe the speakers as well then the door is attatched with clips all along the side so you just pop them out
Old 01-31-2007, 07:03 PM   #4
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
i had the same problem once...one day just slammed the door and it started working again
Possible Electric Seat Swap? barry E46 4 12-30-2006 01:37 AM
rear blind help zx7rhitch E36 12 05-30-2006 02:11 PM
Replacing rear window (convertible) etubridy E36 6 05-10-2006 06:01 PM
front window motor brien4787 E36 9 02-08-2006 11:29 PM
Rescuers: 'lift Your Tops' zeaq328i United Off Topic  **FOR MEMBERS ONLY** 19 09-09-2005 07:00 PM
