Old 01-18-2007, 04:12 PM   #1
g328is
Your Ride: 1996 328is
question for disconnect the battery for replacing the cluster bulbs
hi guys,
gonna try to do my DIY replacing bulbs of my cluster, also set of chrome rings~
sorry, i am noob about this battery disconnect thing, so which terminal? just (-) or (+) or both?
by the way, the steering wheel can't be adjust, so i have to turn the wheel to take the cluster out, if i disconnect the battery, i still can turn the wheel if i put the key in position 1?
thanks guys!
Old 01-18-2007, 06:30 PM   #2
3050rpm
3050rpm's Avatar
You only need to disconnect the (-) cable, just be sure to put a rag between it and the battery to prevent inadvertent contact. Also, make sure you have your radio code beforehand if you have that type of radio, otherwise it's major headache time.
The steering wheel lock is mechanical, not electrical, so you'll be okay (although I can't see how turning the steering wheel will facilitate removing the cluster).
Old 01-19-2007, 01:49 AM   #3
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
actually, turning the steering wheel makes getting the cluster out much easier (at least it did inmine) Due to the limited space between the dash and the steering wheel, plus the overall size of the cluster, you have to pull the top of the cluster out & down, turn the steering wheel to the left, and slide the cluster out. Either that, or remove the steering wheel (which if you have an air bag in it you have to be careful)
Old 01-19-2007, 04:02 AM   #4
3050rpm
3050rpm's Avatar
Ooo, thanks for that tip
DIY: Replacing Instrument Cluster Lights mullethunter3 BMW OEM Parts Department DIY's & FAQ's 41 01-06-2008 02:16 PM
How to change bulbs in the instrument cluster Bimmersrbest E36 8 05-31-2006 04:41 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 12:05 PM
