Old 11-19-2006, 04:05 PM   #1
larsonc
Your Ride: 1989 325i
Unhappy Radio & Warning Light Problem
Hi
I just found this forum and have recently bougfht a 1989 325i. I’m hoping someone here can give me some advice on a problem I’m having with the stereo and anti-lock brake warning light
My daughter had a dead battery a couple of days ago and after first trying to boost the car (unsuccessful), charging the battery (which worked) and then replacing the battery we found the stereo (original Blaplumkt system with anti-theft) doesn’t work and the anti-lock brake warning light has come on.
Normally when we’ve had a dead battery before I just turn the radio on and punch in the code and we’re good to go. This time we don’t even get that option as there appears to be no power going to the radio and the antenna is stuck half way up. I checked the fuses and even thing looks good and I even swapped out the fuse for the radio with a new one and nothing changed. Any suggestions on what to do next?
The other anomaly was the anti-lock brake warning light coming on after we hooked up the new battery. Any idea why this would happen?
Thanks
Curt
Old 11-20-2006, 12:00 AM   #2
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Sounds like something might have shorted maybe? Try unplugging the battery for about 30 minutes and the restarting it.
Old 11-20-2006, 12:06 AM   #3
Rate My Car: 84 / 337
I think the stuck antenna is draining power. A guess, and my anti lock light comes on at random
Old 11-20-2006, 12:12 AM   #4
RSF5
RSF5's Avatar
^^^ hahaha, I hope one day your brakes don't lock up and your just like "Oh Shit, maybe I should have payed attention to the light."
Old 11-20-2006, 12:15 AM   #5
Good one
Old 11-20-2006, 02:41 PM   #6
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
When i had my battery disconected the other week when I hooked it back up and started the antilock light came on for about 3-5 seconds and went off I think it was just a battery disconnect thing. As far as the radio I was going to say try the code but you did that already, so I don't know. Good Luck.
Old 11-20-2006, 08:35 PM   #7
larsonc
Thumbs up
Thanks for the suggestions. I'll try the battery disconnect idea and see what happens. I hope the antenna isn't drawing the power down or I'll be back out there trying to boost it again for my daughter
brake pad warning light DEATH2000 E36 13 11-15-2007 08:14 PM
fog light problem HELP! Tochenzo Lighting 6 10-10-2006 11:32 PM
Warning light callanz E36 10 06-12-2006 06:59 AM
Scanner & Warning Light reset CWatts Z Series (Z3, Z4, Z8) 0 06-08-2006 08:41 PM
