Old 07-20-2006, 07:23 PM   #1
white
white's Avatar
Rate My Car: 232 / 337
Your Ride: 1987 325i
odd lighting problem
whats up eveyone. I have a slight problem... everytime I put the clutch in, all my brake lights come on . Any suggestions on going about fixing said problem??? Any help would be greatly appreciated.
1987 325i, 160,000 miles? 5 speed, pretty much stock
http://www.cardomain.com/ride/2400037
Comments welcomed...
Old 07-20-2006, 07:28 PM   #2
Rate My Car: 183 / 337
sounds like theres an electrical problem, you see, theres a switch right above the brake pedal, called the brake switch, which ones u push the pedal, turns the brake lights on, and there is one infront of the clutch too, thats for the cruise control so it turns it off once u push the clutch in, are you sure they arent switched? wat happens when u push the brake pedal?
Old 07-20-2006, 07:49 PM   #3
white
white's Avatar
the brake lights work normal when I hit the brakes, they all come on and they do the same thing with the clutch when its depressed all the way down. I made sure that it wasnt just my big ass foot (14) hitting both the pedals at the same time which happens in my dads toyota truck, but thats not the case.
Old 07-20-2006, 08:07 PM   #4
oh, it only happens when the clutch is alll the way down? man i havent got the slightest clue, if there is a switch that is triggered whent he clutch is all the way down(for like the starter to start the car) you may wanna look at that see if its shorting or something
Old 07-20-2006, 08:37 PM   #5
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Check your brake fluid level, the clutch runs off of the same system as the brakes, it might be low on fluid causing the brake fluid light to come on when you press the clutch.
Edit and what exact lights come on if its the brake fluid one then this is probably your problem if the park brake and brake lining lights come on it might be something else.
Old 07-20-2006, 11:00 PM   #6
i think he means the tail lights, like the brake lights as if he is pressing the brakes
Old 07-20-2006, 11:20 PM   #7
Rate My Car: 84 / 337
I have heard that there is sometimes a connection between the clutch and brake levers. That may mean that the clutch moving causes the brake lever to move, and then the light brake lights come on from the brake lever switch
Old 07-21-2006, 04:57 AM   #8
Rate My Car: 106 / 337
^^^That's the only thing I can think of. Are you snagging a wire or something down there, causing the brake pedal to get pulled along?
Old 07-21-2006, 04:19 PM   #9
white
white's Avatar
I just went out a looked up there, and there is no wires getting caught up and pulling or hooking the pedals and the brake fluid is full, Im out of ideas as of the moment.... any other ideas?
E36 : anyone had this problem? akinthecat E36 6 09-28-2007 04:35 PM
another lighting problem for me... BaLAnCe17 Lighting 5 06-13-2006 10:18 PM
problem with cams e30boarder E21, E30 3 09-06-2005 09:44 PM
