Old 05-06-2005, 06:52 PM   #1
BimmerKris
Fluids
im doing the oil trannie and diff this weekend. I have a small leak and the transfer case and want to know if anyone knows if there is a good additive that stops a leak like that. also, what is best for the diff (2.93LSD) and what is the stuff called for the LSD clutch?
cheers
www.acantha.ca
100% balls to the walls metal
Old 05-07-2005, 03:37 AM   #2
guywithblack88e30
Rate My Car: 274 / 329
i have only heard of manual tranmission lube dawg nothing else
Old 05-08-2005, 10:13 PM   #3
hamann318is
Rate My Car: 82 / 329
Where is the leak on the transfer case?
The only oil I use is Redline. I have Redline MTL in the transmission and Redline 75w90 in the differential. The differential oil contains the LSD additive, so you don't need to add anything.
What in the hell is a LSD clutch?
The BMW 318 is back. With a vengeance.
Old 09-04-2005, 05:03 PM   #4
defkon99
defkon99's Avatar
Rate My Car: 51 / 329
Your Ride: 1993 E36
yo so just wondersing what Fluid you guys reccomend to
93 325i
Auto trans Fluid ?
Differential Fluid?
Power steering as well....
Mmmm.. fluids catalyst E36 20 02-14-2006 10:47 PM
