Ok so one of my instrument cluster lights seemed to be loose. So i went ahead and removed the cluster to see what was up. Also everyonce in a while my temp gauge would freak out and bounce all over the place. So i figured it was the batteries in the cluster
after taking out the cluster, looking at it i discovered teh bulb was jsut loose, and the batteries are not leaking at all. So...not sure why the temp gauge is tweaking, but atleast i fixed the cluster light bulb.
Either way removal is quiet simple in my 1991. Ill take pics, but its night time, so they may not be that great.
anywho..thought i would share.
Ill post pics later.
Hurray for having nothing to do on a saturday night.
ok after further inspection i realized that the bulb is also burned out. Not sure if i just did that or not..but the filiment is definately burnt out.
So ill pick up a new one tomarow and finish the DIY after i replaced the bulb.
i got the bulbs. replaced them. put it all back to gether..and realize that my Brake lining indicator bulb was out also...so i took it back apart and in the process borke the corner of the plastic shroud covering my instruments.
Now i gotta go to a BMW yard and find an E30 and get the replacement part.
DIY will be put together after i do that.
GODAMIT either way...cause i fixed one thing and broke another.
Your Ride: E39 525d
Hi i have just taken out my 2002 dash as the speedo/techo guage isn't lighting up but there are no bulbs visable as in the pictures have anyone got any idea's????
