Old 05-30-2006, 11:39 PM   #1
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
Engine stops oddly.
so i have nmoticed that when i turn my car off the engine keeps turning and it sounds like it rotates a couple of times after the explosions stop.
What could be causing this?
I put 91 octane in the car.
Old 05-31-2006, 12:12 AM   #2
Spieluhr
Title: ///M Driven
that sounds really weird, the engine should not keep moving.
Old 05-31-2006, 12:22 AM   #3
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
What could be doing that? is the car automatic or manual?
Old 05-31-2006, 04:10 AM   #4
Rate My Car: 137 / 337
Do you mean it's "dieseling"? (like running on) If that's the case after you put in 91 octane could be a carbon build up causing pre-ignition. When was last plug change? Does it do it everytime you turn it off or only after certain circumstances? (more info please)
Old 05-31-2006, 10:56 PM   #5
Numark318i
Numark318i's Avatar
Your Ride: ^^
yes dieseling if thats what u call it.
Changed plugs about 15-20k ago. New wires also. Bosch all around.
Usually only does it when its hot, when i take a drive longer then an hour or when i drive spritedly.
Old 06-01-2006, 12:29 AM   #6
Run a bottle of Techron or STP gas treatment and fill up tank at same time - see if that helps. It sounds suspiciously like bad fuel and/ or moisture in gas
Considering Buying An E30?Upgrades?Differences? spiff E21, E30 30 04-14-2012 10:12 AM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Car stalled and now engine won't turn over... looking for any ideas/help komodo M3 21 05-22-2006 11:15 PM
Search Engine Optimization and Tweaking komodo United Off Topic  **FOR MEMBERS ONLY** 23 04-07-2006 11:12 AM
I finished the engine swap htp.bmw E21, E30 7 06-21-2005 11:33 AM
