Old 04-17-2006, 11:11 PM   #1
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
I fix one thing..another snaps....wtf
Ugh. Sometimes it feels like my car is a constant head ache..but its worth it.
I just flushed my power steering because it was getting harder to steer. So I put some dextron 3 ATF in it. Works beutifully now. Less then 24 hours later Im driving over my mountain pass, haulin ass as usual and i take a hard right handed 20mph turn at like 50. Heel toe downshift, cut apex..the whole shabam.
I get through the turn, my brake sensor light comes on and a little later when i slowed down I heard a rattling. I keep driving because i was tight on time. Get to my destination and by then my brake lining light goes out(wtf? this happen to anyone?) but i find out i snaped one of my exhausts hangers. It snapped right in half...how the hell does that happen. No rust or anything, just broken.
so my quiestion is if i take it off, which i have can i drive with only one hanger?
Old 04-17-2006, 11:25 PM   #2
Rate My Car: 84 / 337
This so sounds like my E30 - but my exhaust is different being the 6. Hope a quick fix is on
Old 04-17-2006, 11:37 PM   #3
Rate My Car: 183 / 337
you can definately drive w/one hanger, but if it shakes too much, the exhaust might slip off from that 1 hanger and be hangin down(its still held by bolts) which is a bad thing, but its no big deal, just take it to a shop and have them weld one for you, or you can even go to autozone and get ur own universal hanger for like 5 bucks
the brake sensor is probably lose btw
Old 04-17-2006, 11:41 PM   #4
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Yea the hanger is probably a quick fix, and loose sensor as xsperf said if probably the culprit, otherwise your pads might be starting to get thin.
Old 04-17-2006, 11:52 PM   #5
Numark318i
Numark318i's Avatar
Your Ride: ^^
kk. well ill drive with it as it is for a while. Doesnt seem to be causing any trouble. when ever i get time ill get a new hanger.
as for the sensor ill check it and see if its loose.
Agh...always somethign to fix. But godamit its worth it.
Old 04-18-2006, 12:30 AM   #6
Storamin
Storamin's Avatar
Title: Road Kill
it's an e30, what do you expect my man in red?
Old 04-18-2006, 10:44 AM   #7
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Ummm hello?
You drive an e30, they are old.
What else did you expect an e46 M3?
Old 04-18-2006, 10:59 AM   #8
Numark318i
Numark318i's Avatar
Your Ride: ^^
Originally Posted by BMWLotAttendant
Ummm hello?
...its only 15 years old...
Old 04-18-2006, 04:35 PM   #9
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
No no my story so has yours beat. Im taking a right turn from a red light, no headvy aceceleration just a normal pull out into traffic and the strap on my gas tank decides so snap in 1/2. Ofcourse it was very rusted. So im trying to figure out while I find a spot to pull over whats under my car draging down the road. Lucky for me its only a 10$ part so Im dong both of them while Im under there.
Old 04-19-2006, 01:01 AM   #10
Numark318i
Numark318i's Avatar
Your Ride: ^^
heh oh shit. I should prolly make sure mine is still in good condition. Maybe u should change ur exhaust hangers while ur down there.
also..Im pissed. flushed my power steering...now its leaking again. Im so godam annoyed. I tightened everythign down, nothing should be leaking. BUT it still is.
Arg. Now everytime i park somewhere i leave a some spots of ATF fluid. Then my water pump is squeaking..which makes my car sound ghetto..haha.
well what ever.
Old 04-19-2006, 01:33 AM   #11
BMWLotAttendant
yeah, soooooooo e30 NFTW!
Old 04-19-2006, 02:10 AM   #12
Numark318i
Numark318i's Avatar
Your Ride: ^^
....look at any other 16 year old car. E30 FTW.
anyways...car is amazing once i get past all the things breaking. Plus i drive my car hard...that prolly doesnt help.
Old 04-19-2006, 05:50 AM   #13
Rate My Car: 137 / 337
Numark - you need to intesify your maintenance schedule. You do your oil changes religiously right? If you're going to hammer on your car you need to be doubling your maintenace routine and checking eveything more often or you're going to be writing more threads like this one. You can't expect a street car to be a part-time racer on a street car maintenance plan. Especially one that's getting up there in age. You're only going to amplify the weak points. (like brakes, wheel bearings, exhaust parts, belts, hoses, berings, bushings, shifter,plugs +++)
Guide - a good hard weekend on the track = roughly 5k in street driving
Old 04-19-2006, 03:15 PM   #14
Storamin
Storamin's Avatar
Title: Road Kill
Check out new clamps for your PS system.
Old 04-19-2006, 03:26 PM   #15
nick_318is
nick_318is's Avatar
No, e30 FTW, they are sweet cars and I can't think of many other 16 year old cars that still work as well. C1apton brings up a good point, but I dont think he has tracked his car yet, the track stuff breaks and you learn what likes to brake (i have blown through some wheel bearings, a caliper and some other stuff i'm sure I am neglecting.)
I currently need a new antenna mast and/or a motor cause I cant get shit on my radio and the thing doesnt go up, somehow the one station I listen to here still comes in so I haven't played with it yet.
Windows Dont Roll Down , Wtf!!! defkon99 Car Audio and Electronics 8 10-30-2010 12:54 PM
Fix for infamous LBF problem habbie Lighting DIY's 0 03-17-2006 09:57 PM
My Dilemma: Fix my damn sunroof!!! Beater_Bimmer E36 10 08-04-2005 12:55 PM
Wtf? Chris United Off Topic  **FOR MEMBERS ONLY** 7 06-19-2005 11:49 AM
Favorite Thing You Like About Your E36 jrhaile E36 46 06-03-2005 03:08 PM
