Ok i want to get sway bars for sure. Im not sure whast i want. I was looking at E30 M3 bars, they are 19mm in the front and 14mm in the rear stock. I got 20mm front and 12mm in the rear. If i just buy a rear M3 sway bar will the 2mm make a noticible difference?
Also if i got his way ill buy poly urethane bushings for the bars.
input?
I wanted to go with BMW parts cause all the other companies are adjustable...and thats just a pain in the ass?
what u guys think
Don't go with the m3 bars...
Go with an aftermarket set. The adjustable ones are very nice -- if your car understeers or oversteers it's one of the ways to help adjust it. Poly bushings are much better.
Buy a M3 rear bar and call it a day. You won't be able to fit the front bar unless you buy M3 sway tabs, and you have a welder.
The rear M3 bar adds 2mm to the rear and gives it a touch more oversteer. It's a nice setup. I wouldn't do anything more.
What he said. It seems like you dont want too aggresive of a set-up so I would just go with M3 rear bars and PU and you will surely notice less rear body roll but a little more oversteer.
alright.
i think thats what ill do. ordering parts monday from the stealership
Ill give the first person who finds me PU 20mm front sway bar bushings, and 14.5mm PU rear sway bar bushings 7 dollars via paypal.
...i have looked all night and found nothing.
Save the paypal bucks...
Factory BMW - front (20mm) -pt #31351130850
" " - rear (14.5) -pt # 33551129194
Have to check dealer for current prices..
sweet stuff. those will fit right? Ill call them tomarow and see. if they got a 14.5mm , or can make me one ill send u the money
