Old 09-01-2012, 04:28 PM   #1
Rower2x
Your Ride: 1990 325i
Unhappy E30 Driver Door Electrical Connector
I had the drivers door on my '90 325i replaced from an accident last year and now the electrical connector from the '88 salvage door has an intermittent electrical contact with the body connector. The short makes it difficult to open the gas cap at times and I'm looking for tips on how to fix this issue. Are these door wiring harnesses interchangeable?
Does anyone know how to remove the connector from the body so I can spray some contact cleaner into the connector halves? Can't seem to pull out the plug. Is it bolted together or just tabs?
I'm also looking for a new instrument cluster if any know of a good working unit.
Old 09-03-2012, 09:08 PM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 111 / 340
The wiring harness for the door is interchangable. However make sure if you have a Coupe you get a Coupe harness, and a Sedan a Sedan harness. Different doors.
Download a copy of the E30 Bentley Manual. I believe removing the door connector is covered in their, as it is in the E36 Manual.
VIEW MY E36 BLOG HERE
$2500 e30 coupe or $2000 e30 sedan eurols1 E21, E30 1 12-24-2010 12:06 AM
Car and Driver drawing flak over Photoshopped BMW X6 M drag racing pic? scooter BMW News And RSS Feeds 0 10-05-2009 06:50 PM
Eliminating Posers, With a E30 Empty Box Kill Stories 14 07-25-2007 02:10 PM
e30 M30 project has BEGUN!!!! devinwwu E21, E30 152 12-18-2006 06:05 PM
