Old 11-28-2005, 09:21 PM   #31
htp.bmw
yea im not sure how the new oil pan would do with one oil sump
Member of the Top Down Club
Old 11-29-2005, 02:59 AM   #32
bex325
again... the engine is the same, oilpan is virtually same design, just with the driveshaft running through. the problem is with the strut towers. take a look at the engine bay of the ix and you can see that they are almost vertical compared to the rearwards cant of the rwd cars.
I'll say it again though... the main problem is not with the front suspension, its with fitting the transfer case into the Cabby chassis, the additional cross-bracing would probably get in the way.
If you do still consider it, you will need at least: front subframe, control arms, strut towers, ix tranny (regular getrag 260, but different casing), transfer case, and more.
IMO i think it would be cool to do, but really why? the cabby is already the heaviest e30, and the ix is the 2nd heaviest, so by combining them youd end up with a car that weighs as much as an e36, and come on we all know that that isnt very good now is it? (jk!)
I recently went through the same issues with regards to trying to make my cabby an all-purpose car (track, road, etc.) but i realized that it makes more sense to leave the cabby as is for summer cruising, and modify the coupe for the track. it makes much better financial sense, and the end result is better. But i do have a plan to get top-down fun combined with trackability... Im going to Deutscheland next summer and picking up a Baur TC (which did come in ix versions...)
to sum up:
ic + ix = heavy! = not good + expensive = not worth it IMO
(woah long post)
----------- 1986 325 ------------------------------------------------------------- 1987 325ic -----------
Old 11-29-2005, 10:42 AM   #33
htp.bmw
alright thats what i wanted to hear from this post bex325 i appreciate your input, i didnt realize how different the strut towers. I have found one that needs some tlc surface rust (frame is still good) for a grand so im gonna look into that.
Old 11-29-2005, 07:35 PM   #34
Rate My Car: 183 / 337
in that case, just get some really nice studded snows, believe me they'll work
Old 11-29-2005, 07:39 PM   #35
jybute
jybute's Avatar
Ill give him $50
Old 11-29-2005, 07:49 PM   #36
craig
craig's Avatar
Title: Sitting in Time out
seriously tho... i have a three car garage(well my parents anyway) and am willing to store it. only one spot is taken... it would have to drive on dirt tho... so that wouldnt work so well. anyway.... good luck with finding an IX.
Old 12-03-2005, 08:48 PM   #37
austin
Rate My Car: 150 / 337
iX's are garbage. if you want awd, buy an audi. sure its awesome when it works, but it will go bad. my iX did exactly what almost everyother did: the splines on the front axle stripped out. there are ways to prevent this, but the car will end up being a money pit. as far as a conversion, the shock towers on 2wd versions are slanted back, and the iX towers are straight up and down. also, the rear brakes are different. the engine itself is the same though
1999 528iA
1998 318ti California Sport
Old 12-03-2005, 09:57 PM   #38
TJsBimm
Rate My Car: 222 / 337
Your Ride: 97 328i
winter tires they will do wonder's believe me! You won't have to do all that crazy expensive shit to your ride and you'll be able to keep it at the same time!!!!!
Old 12-04-2005, 12:21 PM   #39
hamann318is
Rate My Car: 88 / 337
The engine's oil pan and dip stick are different on the IX, and the shock towers are completely different. If you actaully got it done, it would weigh way too much.
The BMW 318 is back. With a vengeance.
Old 12-14-2005, 08:53 AM   #40
e30cabrio
Rate My Car: 95 / 337
If you could get an ix the was damaged in back (cheaply) you could cut the front end at the shock towers and have it welded in BUT it would be really expensive and iffy on the structural rigidity factor. Cool idea but most likely very expensive to do right.
5-speed conversion. Spieluhr E36 45 01-28-2006 05:10 PM
obd1 conversion B_w. E36 8 12-02-2005 05:25 PM
s14 to s52 conversion. craig M3 9 10-15-2005 11:16 AM
Headlight conversion DIY billycuth E36 10 07-28-2005 01:29 PM
h7 fog conversion BaLAnCe17 E36 15 07-03-2005 06:01 PM
