| E21, E30 General discussion and technical help for 1975-1991 3 series cars. |
11-08-2005, 06:54 AM
#1
Central Locking
Bubba here with a 1990 325ic and the pasenger door cannot be unlocked by any means (trunk is OK). I can lock the drivers door by getting in, shutting door and pushing lock button down and also unlokcthe same way or by lifting inside handle. If I lower drivers window and push lock button down, the door locks and I can unlock by use of the key, however, I cannot lock with the key. I have had her all apart and believe the drivers door lock motor is gone so I ordered (from salvage with a six month warranty) both the central lock module and a ddriver's door lock. I also believe that the drivers door lock key cylinder does not have enough force to move the fork (that the leg on the lock cylinder fits into on the door lock) to lock the door (I can remove cylinder and reach in and with door shut, lock and unlock with my door on the lock fork). Ihave read many DIY form various E-30 sources, but if anyone else wishes to step in, I would appreciate it. Also, if I get her fixed, I will post the results.
11-20-2005, 01:40 PM
#2
sounds good I would be interested in the results. when I got my first convertible (now parts car) One of the doors was locked shut and wouldnt open and it turned out that it was the locking unit at the bottom that automatically lockes the door with the key had seized in the lock position good luck with fixing it.
Member of the Top Down Club
11-20-2005, 09:42 PM
#3
Yes, the locking motor on drivers door was shot so it kept the pasenger door in a fully locked mode. I replaced the lock motor and all is well except I cannot lock the car from the drivers door lock. If, however, I lock the car using trunk or passenger door lock I can unlok the car using drivers door lock.
11-25-2005, 07:37 PM
#4
Your Ride: E30 325
my central locking system is wacky like that too
12-29-2005, 01:29 AM
#5
Title: has an empty wallet
Your Ride: ^^
bump....anyone...or read my other thread.
We all get the urge...Saturday early morning...nothing to do till noon...  BMW FTW
