Old 11-07-2005, 03:42 PM   #1
325Extatic
Removing a rear brake rotor
Hey all, I was doing a brake change including rotors on the rear of my car the other day, and the rotor retaining bolt for my second rotor stripped out. I can't use an allen key to remove it anymore... should I just drill out the head of the bolt, and pull the rotor over the stub, then work on the rest of it afterward? I have ordered some new bolts to replace all of them, but how do I deal with this one?
any help would be appreciated!!
Thanks!
Josh W.
I Fling Poo... It's What I do!
Old 11-07-2005, 04:53 PM   #2
Rate My Car: 136 / 329
You can drill it out or use an "easy out" (drill a hole, insert EZ out and turn it out) but whatever you do - don't drive it until you get your new bolts. You'ld be playing "russian roulette" with your new brake parts driving without that hold-down bolt.
I know of people who have driven with them out - but with heat, expansion and the width of lug bolt threads there's a possibility of the rotors "flexing" under braking and it's not worth the price of your work & $$$ taking the chance.
DIY Brake Pad Change nick_318is BMW OEM Parts Department DIY's & FAQ's 6 08-25-2011 10:23 PM
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 12:02 PM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 11:41 AM
BMW Inspection Rooz BMW General Discussion 21 03-14-2006 02:10 PM
E30 Brake Pad Changing Procedure nick_318is BMW OEM Parts Department DIY's & FAQ's 6 10-14-2005 06:36 PM
