Old 11-06-2005, 01:14 AM   #1
j123crx
what if ? intake ?
if you ran a cone filter directly to the engine and bypassed the mas what would happen ? leaving the mas connected but not interupting the airflow. would this work, you would need to get cold air to the mas for best function right ?
Old 11-06-2005, 01:29 AM   #2
Hoppy
Hoppy's Avatar
Title: fueled by bourbon
if ur MAS doesnt read right, your engine wouldnt be getting the propper amount of fuel.
You know your a drunkard if you...
Think box wine is great; eagerly awaiting box whiskey.
Originally Posted by RSF5
Well yeah, the BATFE is like the Anti Hoppy.
Well hey, hey Mr. Policeman
Bet I can drive faster than you can
Come on Hoss, let's have some fun
Go on shoot me with your radar gun
You look bored and I sure am
Catch me if you can.
Old 11-06-2005, 07:39 AM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 176 / 329
Put the MAS connet it directly to your intake via home depo drain pipe connections. Then conenct your cone to the end of the MAS.
Old 11-06-2005, 08:56 PM   #4
j123crx
heres what i got so far. huge cone just in front of the MAS, mesh screen in the headlight hole so i have almost direct airflow from outside. i need to built a cone shield. would the direct flow from the filter to the TB work better if the MAS was not in place. would the MAS read functionally if located on the interior fender under the hood ?
Old 11-09-2005, 01:38 AM   #5
hamann318is
Rate My Car: 82 / 329
No.
The BMW 318 is back. With a vengeance.
Old 11-09-2005, 03:11 PM   #6
Bubba
What If
The big thing is to get that filter out of the engine compartment (unless you encase it in the big plastic box just forward of the AFM )and all of that heat. Also, if you use a K&N filter do not over oil, it does not take much, (good question on this in current Raod and Track in the technical question section).
Old 11-10-2005, 11:21 AM   #7
hamann318is
What are you talking about?
Listen, you don't have a MAF. The M20 has a AFM, and there is no way you can bypass it. The engine's vacuum pressure is what moves the metal flap. The car will not know how much fuel to add, and you will have many many problems.
Stick with your stock intake, and get a K&N panel filter. If you're after a CAI because of the sound it makes, then drill your airbox below the filter. There is no reason to do a CAI on a E30. The air passage is all ready very direct and flows nicely.
Old 11-18-2005, 01:44 PM   #8
325Extatic
THANK YOU! I was gonna go crazy trying to figure out how he got a MAF engine when it would take THOUSANDS OF $$$ to get that conversion done right on a non "M" e30!
And Hamann is right, the intake setup on our engines is pretty direct and pretty good! Leave it alone, just punch a couple holes in the lower section of the air box for the "Intake Howl" that a CAI would give you!
Just my .02
Josh W.
I Fling Poo... It's What I do!
FS: E46 GruppeM Cabon Kevlar intake! Nics Bmw Cars For Sale/Wanted 6 02-16-2006 07:59 PM
intake question... ivopivo E36 21 11-21-2005 02:44 PM
M50 Intake MF/Shrick Intake MF Deloriant E36 31 07-23-2005 10:13 PM
WTB ECIS or others intake ///Menace328i Bmw Cars For Sale/Wanted 4 07-22-2005 10:55 PM
FS : E36 ECIS Intake mpowerd Bmw Cars For Sale/Wanted 4 07-11-2005 05:55 PM
