CHASSIS
Front suspension: MacPherson struts, coil springs, lower control arms, swaybar
Rear suspension: Semi-trailing arms, progressive rate coil springs, swaybar
Steering: Rack and pinion, power assist
Steering ratio: 20.5:1
Front brakes: 260mm discs
Rear brakes: 230mm twin-shoe drums (self-adjusting)
CHASSIS
Front brakes: 260mm ventilated discs
Rear brakes: 260mm discs
ABS standard in model year 1986
CHASSIS
ABS standard
5-speed Getrag 260 (manual)
Ratios:1 (1/2/3/4/5/R): 3.83 / 2.20 / 1.40 / 1.00 / 0.81 / 3.71
4-speed ZF 4 HP 22 (automatic)
Ratios:1 (1/2/3/4/R): 2.48 / 1.48 / 1.00 / 0.73 / 2.09
Final drive: 3.73:1
4.10:1 (325iX) also has center differential w/viscous coupling,
27%/63% f/r torque split
CHASSIS
ABS standard
14x6.0 alloy wheels on 195/60HR14 tires
14x6.5 alloy wheels on 195/65VR14 tires (325is)
15x7.0 alloy wheels on 205/55VR15 tires (325iX)
CHASSIS
Steering ratio: 19.6:1
Front brakes: 280mm ventilated discs
Rear brakes: 282mm discs
ABS standard
CHASSIS
Rear brakes: 262mm discs
ABS standard
14x6.0 steel wheels on 195/65R14 tires (318i)
14x6.0 alloy wheels on 195/65R14 tires (318iC)
14x6.5 alloy wheels on 195/65R14 tires (318is)
It should, yes. I didnt create the list though so their is a possibility it is an error.
On a side note, when did you get an X5? If you havent already Jybute, you should check out Project Technik. Its an Alberta based group. www.projecttecnik.com. My board name over their is Vader.
