Old 04-08-2011, 10:19 PM   #1
nate8809
Your Ride: 1990 325i
325i will not charge!!!
Ok so ive been working on my brothers car its been broke down. Probably for a couple months. So I try to go over there today and he's replaced the battery once and the alternatore today! This is alternate number 2. The voltage started out at 12.2v and slowly goes down as time passes. Within 30 min its dead completely. He was told by a mechanic that the signal wire to the alternator could be bad so he rwplaced it still no change!!! Is there some kind of alternator relay or something blocking it from getting the hint to kick on? He said when the car died on him he and a friend jumped it off! Well the guys apparently made a big whoops and crossed the jumpers! So maybe the pcm is bad???
Old 04-11-2011, 06:50 PM   #2
Big Evil
Big Evil's Avatar
Replace the battery light in the dash. Its the fusible link in the system.
Old 04-12-2011, 07:52 AM   #3
nate8809
Seriously damn little dash light causes this much of a problem? He bought the care and the dash lights are rigged to a battery pack in the glove box? Is this right? An%d if its not the dash light is there anything else to look fodor?
Old 04-12-2011, 08:09 AM   #4
Big Evil
Big Evil's Avatar
There was a small battery pack in the dash that got deleted on later E30's. There shouldn't be a pack anywhere else in the car. Is there any aftermarket stuff on it?
And yes, that little battery light in the dash burning out will cause the alternator to not charge the battery. I've bought Beemers for next to nothing because no one bothered to figure that out and it was on "non-working" alternator number 3.
Old 04-12-2011, 08:12 AM   #5
nate8809
No its completely stock. Guess ill head over there and try to find this little light bulb!!!!
Old 04-12-2011, 08:15 AM   #6
Big Evil
Big Evil's Avatar
Pull the steering wheel (make sure the key is turned to the unlock position to remove the wheel). Pull the dash cluster out, its on the right side (while facing the gauges) along the bottom. While its out check and replace any and all burned bulbs.
Old 04-12-2011, 08:19 AM   #7
nate8809
Guess I'm gonna need to take my steering wheel puller
Old 04-12-2011, 08:22 AM   #8
Big Evil
Big Evil's Avatar
No puller, you'll damage the wheel lock. Just undo the bolt, turn the key and the wheel will come right off. Mark its position before you pull it, it's designed to be easy sine the older ones required a SI board replacement as a part of regular service (that's what had the battery pack in the dash)
Old 04-12-2011, 10:06 AM   #9
nate8809
Light bulb is good
Old 04-12-2011, 01:26 PM   #10
nate8809
New light bulbs new wire from alt to starter new ground wire from alt to chassis still no charge! Anyway to check and see if exciter wire is working properly! Maybe unloader relay I'm completely stumped
buying a 93 325i for 500 has trans problems please read keith2shrum1 E36 0 12-31-2010 01:05 AM
325i wheel fitment lsgbimmer32501lee E46 0 12-10-2010 01:09 PM
E46 325i car in US For Sale Lambourne Bmw Cars For Sale/Wanted 9 02-01-2008 08:30 AM
Turbo for 325I? maximk2 E36 9 04-28-2007 09:17 PM
AOL, Yahoo to Charge for Email komodo United Off Topic  **FOR MEMBERS ONLY** 7 02-10-2006 12:29 AM
