Old 06-23-2010, 05:13 PM   #1
zezip
Your Ride: 1984 318i
e30 m10 2nd and 3rd cylinder wont fire
hello,
I have an 85 318i that is frustrating me to no end.
My second and third cylinders are not combusting, the plugs look clean(never fired) and smell slightly of gas and, when i pull out the wire to either of those two cylinders no effect to the rpm or running of the car.
i tryed replacing the injectors,distributor cap and rotor. and i have switched the wires around to no effect. using a screw driver as a "stethascope" i can hear the injectors clicking. i have even pulled off the valve cover to check lobes on the cam and they are fine.
i did at one point have the distributor out of the engine. i dont know if having the gear at teh bottom of the distributor shaft misaligned could account for some fo the symptoms.
please help me and thank you very much for you time,
-Fed up
Old 06-25-2010, 09:30 AM   #2
Big Evil
Big Evil's Avatar
You need to do a compression test.
Old 06-25-2010, 06:32 PM   #3
zezip
hmmm my bad i had the ignition wires in the wrong order for some reason i had them going clockwise round the distributor... but now she shudders. if set the idle high at 2g rpm she shuders up to 2.5 2.7g. any ideas?
Old 06-29-2010, 09:47 AM   #4
Big Evil
Big Evil's Avatar
Compression test?
Money Shift Information bimmersunited BMW General Discussion 1 12-23-2007 05:08 PM
