Old 04-28-2010, 07:58 AM   #1
tiger318i
Your Ride: 1984 318i
1984 318i issues
i have a 1984 318i i received the car from a guy who let his kid change the oil, ran it w/out putting oil back in and seized the engine...bought a "new" engine for it, as well as a distributor, rotor, idle control valve, fuel pump (internal/external), fuel filter, starter, fan belts, and fuel pressure regulator.
k, so the Haynes/Chilton manuals go through test to run if your having problems with your car starting. ive already tested the fuel pumps, spark plugs, starter, and ignition coil, ignition control module, injection control module, fuel pump relay, throttle control (side on throttle butterfly), ecu, fuel injector resistance, and performed a continuity test based on a schematic wiring diagram i found specific to my car (ill upload later when i get a chance). ALL TESTS PAST ACCORDING TO HAYNES/CHILTON'S SPECIFICATIONS. the continuity check i performed passed, so i know there are no kinks or breaks in the wires. I will be running all of the tests again today and tomorrow, just for another go around.
so far the only part on my car i am missing is to the left of the air intake assembly; the Barometric pressure sensor. now some people say that not having this part wont matter, and that my car should start/run without it, others say that its the reason it wont stay running.
i was also using old gas in the car and a lot of people tried to say that was why it wouldn't stay running, but that doesn't seem possible to me.
Now when i turn the ignition on my car, it will start for a quick second, and then immediately die. i was told this is due to the cold start injector, so i know that works.
I have not performed a gas pressure test yet; didnt think i would need to since i bought 2 new fuel pumps, a filter, and a fuel pressure regulator, and the car started from the cold start so i assume that would mean i have the right pressure.
im not missing the Air Flow Meter, its still on there, its the part on the side of the intake assembly; The Barometric Pressure Sensor. it connects to 1 of 2 cables that come from the Fuel Pump Relay (the other cable connection is round, connects to the front of the air intake assembly right behind the driver side headlights and i believe is just another type of oxygen sensor).
But even though i dont have a timing light, i went through months of research to make sure i wasn't 180° off for TDC, so im pretty sure thats fine, the distributor alignment could be wrong though.
The really weird thing is that when i start the car, as i mentioned, it shuts off....however, a few times i would try to start it while holding the pedal to the floor, or after it would start, id try to push down on the pedal, but the engine never reved!? The RPM needle didnt even move, and the engine didnt even "sense" that i was pushing down on the pedal. i checked the Throttle Position Sensor and it passed, and i checked my throttle cable and its connected and moves when i push down on the gas pedal?
Edit/Delete Message
Old 04-29-2010, 09:49 AM   #2
Big Evil
Big Evil's Avatar
Sounds like you have a bad read from a sensor cause by a bad sensor or a wiring issue. The other option is a massive air leak after the MAF. Since the car does start I'd start with the air leak scenario since if you had a bad pump, spark or injector it most likely wouldn't even kick over.
318i losing power Bullishone E36 8 06-17-2010 10:32 AM
many issues gemnilvr 5-Series 1 01-09-2010 03:18 PM
CO: 1984 318i 5-speed LOTS OF PICS $1000 iamcreepingdeath Bmw Cars For Sale/Wanted 2 10-20-2009 01:06 PM
92 318I Mystery For Me and 25 Yr Mechanic BShadows318I E36 17 07-20-2009 08:22 AM
What is the avg. lifespan of an Auto M42 E36 318i? delmarco E36 15 05-31-2005 11:09 PM
