Old 09-16-2009, 01:56 PM   #1
kaugarsa
Your Ride: 1987 325 is
1987 325I high idle
Good afternoon all-as a new member of the forum and the proud new owner of a beautiful 1987 325I, I wanted to say hi and ask for some help.
When I start her up, or when sitting at a stopsign, the idle speed spikes and then stays at 2000 RPM. Based on what I have read in the forums, I cleaned out the ICV, checked for leaks and cracks, and still nothing....as I am a novice at this, would appreciate any and all help.
Old 09-16-2009, 04:29 PM   #2
Big Evil
Big Evil's Avatar
How's the adjustment on the throttle cable? Occasionally they can get bound or the cable stays can pop out and get stuck. Do you have a check engine light or any error codes?
Old 09-17-2009, 09:59 AM   #3
kaugarsa
Throttle cable is good, no issues. No check engine light or error codes either. Short of taking her in to a dealer, I'm baffled.
Old 09-17-2009, 03:44 PM   #4
Big Evil
Big Evil's Avatar
Cleaning out the icv is one thing, maybe the icv itself is bad, or has a wiring issue. Any other ideas out there?
Old 09-17-2009, 05:03 PM   #5
3050rpm
3050rpm's Avatar
No other ideas, just similar experience... My car has done that on three or four occasions over the past few years, but it was only of short duration, at most a couple of days, sometimes for less than a day. About the only thing I can recall is that it seemed to occur with the onset of cooler weather, perhaps when I was only using the car for short hops and it didn't really get the chance to get up to normal operating temperature for a sustained period of time. For some non-rational reason I got the sense that it would correct itself, hence I didn't do anything to check the problem out, other than to take the car out on the highway for a while. Seemed to do the trick, but don't ask my why. Water vapor in the fuel system? Water vapor built up in the catalytic converter, thus screwing up the 02 sensor (I've had that happen too)?
Old 10-15-2009, 11:53 AM   #6
Akuma
Rate My Car: 6 / 337
Might be a faulty air flow meter, I'd get it checked.
1989 BMW E30 325i Cabriolet.
325i noise from engine/trans at idle cold buckles E36 1 10-20-2008 04:31 AM
01' 325i rough idle fmbmw E46 4 10-17-2008 08:50 PM
High rpm's at idle mzbmw325i E21, E30 25 01-06-2008 09:01 PM
325i - Engine surges at idle Jammer3 E21, E30 13 08-09-2006 09:40 AM
325i Idle Control Valve Jammer3 E21, E30 1 07-14-2006 09:29 PM
