Old 07-31-2009, 12:30 PM   #1
crazyeyez462
Your Ride: 1986 325e
Exclamation 325e shake in right rear from stop to 15mph
ok so i am new to the forum and love it so far you guys seem to have a great community going now as for the problem
its a 1986 325e and when at a stop light start to go the right rear will shake really bad untill about 15mph and then die down a little bit
is this a bearing an axle or could it be that the differential i looked into the costs and what a came up with was some new and some used parts
but the differential is 225
axle 150
axle housing 150
wheel bearing 65
it just doesnt make sence that it would calm down after it gets upto speed
-BEn
Old 08-02-2009, 02:21 AM   #2
Big Evil
Big Evil's Avatar
Bad/shifted/bent suspension component or wheel, bad bearing (real beyoch on the rear). Does it make any particular noise and what happened in between running normal and it's current ailment?
Old 08-03-2009, 08:34 AM   #3
crazyeyez462
well it was givin to me by my uncle and he said nothing but idk it could have jumped a curb
well wat would u suggest justt doin the rear suspension or is bearing more probable
Old 08-03-2009, 04:31 PM   #4
Big Evil
Big Evil's Avatar
I wouldn't start shot gunning it with parts and hope it works. Measure the distances of the suspension travel, length of the arms and look at the condition of the rubber bushings etc. With the car raised try wiggling the wheel from side to side to check for bearing play, look at the condition of the cv boots and compare everything side to side as little as 1/8 of an inch can make a difference. When it makes the noise/vibration it's most definitely coming from the rear and not right about where your butt is in the center of the car right? Try switching seats have someone else drive and see if the sounds shifts position, its common for the tranny mounts to collapse and the center support bearing rubber to fail and you get a drive shaft knock at low rpm when starting out but then it goes away. It sounds like the rear end from the drivers seat but moves when you're in the passenger seat.
Old 08-04-2009, 09:01 AM   #5
crazyeyez462
Ok i will check that out i have to drive about an hr to get to the car now so ill updat the post this weekend but thank youf for the help so far
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 11:02 AM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
Rear End Handling Issue Please Help cult E36 17 09-18-2007 01:01 PM
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 02:16 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
