Old 07-27-2009, 03:40 PM   #16
ozzieman
Your Ride: 1991 318is/1988 l6
ok so one of my lines was bad so i replaced it but after that i figured out that the pump is bad because i figured out that the fuel that squirted out was just some left in the line now there is no fuel coming out of the line that goes into the filter but it could be the relay i pulled it out and put it back in i dont know if thats how you reset it or not?
Old 07-30-2009, 09:09 PM   #17
Big Evil
Big Evil's Avatar
A relay will be good or bad, there's no middle ground on them. Cheap to replace anyway. What you need to know is, is there power getting to the pump? Use a volt meter and check it, if there is power getting to the pump and it's still a no go, bad pump. Time for a new one. Just make sure there's no popped fuses and there is in fact power making down to the pump before you replace it, no sense in throwing out serviceable parts over a wiring issue.
Old 07-30-2009, 10:46 PM   #18
ozzieman
ok yea il get my friend over here with his meter it should be getting 12 volts right?
Old 07-31-2009, 12:34 AM   #19
Big Evil
Big Evil's Avatar
Key on engine off right when you first turn the key you should get close to source or approx 12 volts at the pump. Make sure the meter is on and ready because it will only get power for a few seconds to pressurize the system then turn off. Cranking should re-energize it. If you have power at the pump and no pump action, there's your problem. Good luck
Old 08-02-2009, 12:23 AM   #20
ozzieman
okay so i just tested the power thats going to the pump and even when im cranking it over im getting 9.6 volts?
Old 08-02-2009, 03:17 AM   #21
Big Evil
Big Evil's Avatar
That MIGHT be a good reading. I'd expect to see somewhere close to battery voltage (NOT exactly battery voltage, that would be an open ground problem) When it gets voltage does the pump spin? If no then its bad, even with that low reading it SHOULD be doing something.
Old 08-02-2009, 07:57 PM   #22
ozzieman
Yea that was what i was thinking im going to buy one at napa because at the bmw dealer its $550! vs at napa it is $79 im also going to buy a new relay just for the heck of it because its not that expensive plus it could be part of the only getting 9 volts when the battery is getting 11.3
Old 08-02-2009, 08:13 PM   #23
Big Evil
Big Evil's Avatar
Yup, and that battery voltage is technically discharged as well. If you have a charger, pull the battery out of the car and charge it while you do the pump (keeps the danger of sparking and fire down with the battery out).
Old 08-02-2009, 09:43 PM   #24
ozzieman
yea thats a good idea to pull the battery i dont want to jump it very much because i dont want to fry the ecu that would be bad
Old 09-07-2009, 10:29 PM   #25
ozzieman
hey i got a new $430 fuel pump and she finally runs great i did all the maintnence and it is great thx Big Evil
Old 09-08-2009, 07:12 PM   #26
Big Evil
Big Evil's Avatar
Nice work, congrats on the fix
Old 01-28-2010, 04:11 AM   #27
karimMsalama
Your Ride: BMW M5 VW MK2
look at the fuel filter
E30 318i Will Not Start mmihacsi E21, E30 17 12-09-2011 08:44 AM
E30 Restoration Pics Start to Almost Finished...Like it?? Shixapatrol E21, E30 0 02-08-2009 06:00 PM
E30 wont start! nuggiman E21, E30 2 11-12-2008 10:35 AM
E30 won't start - grrrrrrrr! geodanker E21, E30 11 11-07-2007 07:17 PM
15 Things to do in Wal-Mart komodo Comedy Collection
4 10-05-2005 12:37 PM
