Cluster alternator warning light
It says in the Hayes manual:
"On 1982 through 1986 models, a burned-out dashboard warning light will prevent the alternator from charging the battery. After 1987 a resistor is wired in parallel with the warning light in order to allow current to bypass the light in the event of a broken circuit (burned out light)."
Does anyone have any information about the resistor needed?
