Old 03-02-2009, 12:35 PM   #1
vsreeser
Your Ride: 1982 320i
Question e21 will not start
The solenoid will click once then nothing. If I turn the key off, wait a minute or two, then try again, it will do the same thing.
Do I need to replace the solenoid and/or starter, or is there something else I can do? Looks like a real pain to replace
Old 03-02-2009, 05:27 PM   #2
HyeTide
HyeTide's Avatar
Check your battery, make sure it's fully charged?
Old 03-02-2009, 06:30 PM   #3
Big Evil
Big Evil's Avatar
Yup, battery first. Anything less than 12.45 volts and its most likely dead or to discharged to start the car. Two things, if it has juice get a WOODEN broomstick and have someone thump on the starter while you try to crank, occasionally this old redneck trick will get the solenoid to pop loose and work a bit longer. 2, make sure the battery light on the dash is functional (when in doubt just replace it, its less than 3 bucks for a two pack), if its not working the alternator will not get a signal and will not charge your battery, hence a potential reason your battery may be dead. Good Luck
Car Won't Start snumfalzumpa E36 12 08-27-2010 01:10 AM
New to me, '87 325. Yep, No start mooware E21, E30 4 11-23-2008 03:16 PM
02 X5 remote start. not functioning correctly njboost Car Audio and Electronics 0 01-27-2008 01:48 PM
325i getting harder and harder to start gdamato E90 9 07-03-2007 09:59 AM
15 Things to do in Wal-Mart komodo Comedy Collection
4 10-05-2005 11:37 AM
