Old 03-20-2009, 06:08 PM   #16
Big Evil
Big Evil's Avatar
SUPER COOL and good for you, Congrats :-)
Old 05-21-2011, 05:55 AM   #17
freeroamer
Your Ride: 1984 BMW318i
hello all!! and thank you for letting me join...
obviously I have a bmw and have technical issues with it.I have a 1984 bmw 318 i yeah...so anyways i have spend alot of backbreaking leaning over in the engine bay testing for current,ohms resistance...and finally I'm stuck.I replaced the battery and the alternator.checked the bulbs in the new si board all good.I even replaced the ecu.so moving on to my problem i have spark and fuel.But there is a wire that leads from a aluminum box above the ecu above the glove box that goes to the back of the alternator that is supposed to have 2 amps of current and reads 0.this is meant to turn on the stater in the alternator to charge the battery which when barely running reads 11.88 amps and should be 14.4.anyways does anyone one what the aluminum box is called? does anyone have the same car i do and would be willing to read me off the part number for it ? i could replace it if i have a part number....by the way the si board was corroded from old batteries,so i got a batteryless one from programma as well as a ecu....can anyone point me in the right direction?
Old 12-09-2011, 07:44 AM   #18
rudy 8
Your Ride: 1984 318i e30
hi there.....
i have a e30 318i 1984 model bmw.... it wont start.... the car has been standing for a while....put a new fuel pump....changed the injectors the car still does not idle ...the car starts for a sec then stops ...
the spark plugs are dry....
if i put a wire to each injector from the battery direct the car starts ....
its like the injectors are not opening on there own....
please help me.....
E30 Restoration Pics Start to Almost Finished...Like it?? Shixapatrol E21, E30 0 02-08-2009 05:00 PM
E30 wont start! nuggiman E21, E30 2 11-12-2008 09:35 AM
E30 318i (1987) starting problems 2002E30BaurTC E21, E30 2 02-12-2008 12:40 AM
E30 won't start - grrrrrrrr! geodanker E21, E30 11 11-07-2007 06:17 PM
E30 318i vs E46 325i Numark318i Kill Stories 4 06-14-2005 11:43 PM
