Old 10-21-2008, 02:06 PM   #1
Blento
Your Ride: E30 318i '87
E30 rear defogger problem...
...Hi all...
I have a problem with a rear defogger...As it seems it has electric power in window lines..but it wont defogg
I guess that ground wire is disconnected somwhere but I dont know where ground is connected !? ....does anyone knows where should i look for that wire?
Old 10-23-2008, 12:13 AM   #2
mzbmw325i
mzbmw325i's Avatar
Start with the basics, check your fuses first, does the defogger button light up when you push it on, might be bad as well?
Old 10-23-2008, 02:35 AM   #3
Blento
yes button lights up....fuses are OK ...
When I take electrical tester and connect one end to window wires, and the other end to metal where back door locks down, electric tester light up..
So I guess that wire from the window that is connected to the ground lost contact somwhere, but I cant see where that wire goes after where is connected to the window.
Old 10-23-2008, 05:02 PM   #4
theeuroguy
Your Ride: 2000 Volvo V70
I just looked at a wiring diagram and there is nothing tricky about that system, it recieves its power directly from the switch and you have that..What I would be looking for is the physical connection point between the contact strip and the window?, solder connection?.
Old 10-24-2008, 08:09 AM   #5
Blento
every strip has power, so my guess is that wire FROM the window lost its connection...Yesterday I read somwhere that wire should be connected to the ground (G300) somwhere behind the seats.....but Im still not qute sure where is that..
Old 10-26-2008, 01:25 AM   #6
mzbmw325i
mzbmw325i's Avatar
Try the seats then, they are very easy to take out.
rear noise, E30, mzbmw325i E21, E30 20 04-07-2010 10:12 AM
e30 problem need help MaxBoostE30 E21, E30 7 01-27-2010 12:58 PM
Rear End Handling Issue Please Help cult E36 17 09-18-2007 01:01 PM
e30 touring rear bumper any one??? jamesbmw320i E21, E30 5 03-26-2007 03:37 PM
