Old 09-28-2008, 10:28 AM   #1
dev6315
dev6315's Avatar
Your Ride: 1989 325is
Question Do I have a problem or not?
Nice to see the forum is back, i missed it those few days.
Ok, my questions is. I was out playing around this morning and I took a hard launch from a light. When my tires were spinning in first, I felt a knocking under my console, like from the drive shaft. I have a 5spd with a LSD 4:10 rear. Is this normal for he LSD or could I have a problem? I had no slippage or lose of power. I dont normally spin the rears (sport tires aint cheap!) so I never noticed this before. Thanks in advance guys!
1989 325is ///
Old 09-28-2008, 06:18 PM   #2
mzbmw325i
mzbmw325i's Avatar
Since that happened, is it gone or it always happens when you take off from a stop? Could be your guibo or bearing on the drive shaft, can you feel any vibration on the center console as you take off?
Old 09-28-2008, 09:30 PM   #3
dev6315
dev6315's Avatar
No, not normally, only this morning when I had the rears spinning. Even under hard starts or high RPMS between gear shifts its fine.
1989 325is ///
Old 11-23-2008, 03:29 PM   #4
Big Evil
Big Evil's Avatar
guibo or center bearing are the most likely culprits. Had same problem intermittently with Wife's Beemer, dropped exhaust and tunnel cover to find the center bearing rubber shot letting the drive shaft walk around every once and a while. New drive shaft and tranny mounts, no more problems
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 08:50 PM
325 brake light problem fgmx Lighting 2 02-01-2008 01:52 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
528I gear problem, Please help me guys, plz plz djfactor E12, E28, E34, E39, E60 3 10-22-2006 05:56 PM
