Old 03-16-2008, 08:15 AM   #1
orlydj1
Your Ride: 1980 BMW 320i
1980 BMW 320i Gas tank leaks when full
Hi to all,
My question is what is the easiest way to replace the gas tank vent hoses that are on top of the tanks. I really do not want to remove the tanks all the way. Also can I use regular standard size hoses with clamps or do I need to buy metric size. Any diagrams or step by step instuctions are appriciated.
It only leaks when I fill the tanks to the top.
Old 03-16-2008, 03:31 PM   #2
3050rpm
3050rpm's Avatar
I'm not sure, but you may be able to do it simply by gaining access after removal of the rear seat, you would then be staring right at the top of the tank. It might be a good idea to replace the seal at the same time. I don't know about hose sizes, but I imagine any half-way decent parts place would be able to get you exactly what you need, and you might even do all right by checking with the dealer.
Old 03-16-2008, 11:47 PM   #3
orlydj1
Hi 3050 RPM
I already took the rear seat off, also port cover. Took the car to the gas station filled it up and found "No Leak" from the O ring in the sender unit nor from the hose's that were visible. Almost positive the leak is from the left and right vent hose's that are not accesable from the fuel sender port.
Today the oxygen sensor light turned on. I have to research that also.
Thanks 3050 RPM
Old 03-17-2008, 02:03 AM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
remember to disconnect the battery before working on your fuel tank.
Old 03-17-2008, 12:59 PM   #5
3050rpm
3050rpm's Avatar
Well I was hoping the simple approach would do it, but guess not, I guess the tanks will have to be dropped. I don't know if there's a Bentley manual that covers the E21s, but there is a Hanes, and a couple of others I'm sure. Yeah, a bit of a pain, but seeing as those hoses dry out and crack, it's best to get at the whole thing, and also check the connections while you're at it. And for certain, take the necessary precautions when working around gasoline.
Old 03-18-2008, 02:23 AM   #6
orlydj1
Thanks
Look's like I will be looking for a shop to help me out. If I get the right price I will let them do it. In the mean time I will ride on a 1/4 tank. Will let you know.
Old 03-18-2008, 07:55 AM   #7
3050rpm
3050rpm's Avatar
I don't think it's so much a complicated job, as you just need the right setting to do it in, and that means putting the car up on a lift. Not too many of us have that in our garage. In the meantime you're right, just don't fill the tank all the way up, I don't think you have to limit yourself to just 1/4 of a tank though, I think you could do just fine with 9-10 gallons, just to make things a bit more convenient for you. I think the 320i has a 12 gallon tank.
Old 03-18-2008, 05:31 PM   #8
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
My e30 leaks a little with a full tank but only on hard cornering, I have heard this to be the case with others as well.
Old 03-21-2008, 07:56 AM   #9
orlydj1
It's fixed
I called Dinan in Morgan Hill, and asked if the tanks needed removal to replace the vent hoses. Called Dinan becuase I'm only 2 blocks away and well " Dinan" what's better then Dinan. The guy I spoke with told me to bring the car in. I spoke to the mechanic and gave him a new fuel filter. I told him that I took out the rear seat the sender port cover and found after filling the gas tank that the O-ring on the sender was not the source of the leak. (My girlfriend fill up the tank, I observed the sender unit from inside the car. Still leaking gas. It took about $36 in gas.) Dinan installed the filter and I was told they replaced the leaking fuel hose's. I left Dinan $125 short and thought I got a deal. Next day I refilled the tanks and was pissed to find gas leaking. Called Dinan asked why I was led to believe the hose's were replaced. They wanted, after some sarcacism, $800 to remove tanks. Went to 2 other shop's was quoted $300 - $350 plus parts. The 3rd shop Morgan Hill gas, Oriental mechanic's charged me $150 labor $50 parts plus tax, problem fixed for $208 plus $125 rip off by Dinan.
Old 03-21-2008, 01:24 PM   #10
3050rpm
3050rpm's Avatar
I gather this did involve dropping the tanks. All in all, not a bad price you eventually paid to get the job done right, certainly a bargain in comparison to your having to do it yourself. Sorry to hear of the run-around and baloney you previously encountered, you'd think people would be interested in helping out an enthusiast, rather than take advantage of one.
Old 03-22-2008, 08:24 AM   #11
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
^+1
makes you angry when you hear stuff like that
Deus ex machina
E30 325i Touring
BMW 320i Gas Problem rOMa E36 5 06-27-2007 02:40 AM
BMW Worldwide Sales Rise by 11.4% in September komodo BMW General Discussion 0 10-26-2005 01:11 PM
