M42 engine noise *video*
http://i271.photobucket.com/albums/j...h_MVI_6899.jpg
what might cause this sound? it happens on startup when it is cold out. :( |
dd you replace the chain tensiorner lately? Mine sounded like that after i replaced it(for about 20minutes)
Replacement of the tensioner did not fix the noise.
Pictures with the valve cover off: Timing Gears Timing Chain Engine without Valve Cover Does it look like my timing setup needs to be replaced? |
Sounds like as if a lifter has collapased and not filling with hydraulic oil pressure. The cams have to be removed to change them out so you might want to get a professional opinion in person before spending alot of money.
From the pictures your timming gears look fine, if the engine timming was messed up it wouldnt run smooth or even at all. |
Thanks for your input. :) |
| All times are GMT -5. The time now is 12:13 AM. |
