Old 03-02-2008, 02:21 PM   #1
mzbmw325i
mzbmw325i's Avatar
Upgrade control arm bushings
Hi,
Over the week i swapped my suspension from stock "IS" to bilstein sports and M3 springs, what a difference, ride is a bit stiff but i like the way the tires are glued to the concrete now and a nice drop. so my question is to what bushings i can upgrade that will not require to get the car aligned afterwards, or is that inevitable.
i was reading that the suspension is the same for E30, E36 and E46's, which m3 spec bushings are better?
Old 03-02-2008, 02:29 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 132 / 245
Your Ride: ^^
Originally Posted by mzbmw325i View Post
Hi,
Not sure on stock parts, but you may want to try powerflex PU control arm bushings?
Old 03-02-2008, 02:51 PM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 155 / 245
I have the full rubber bushings on my car. I believe they are the m3 bushings. There will be no alignment required since only toe is adjustable.
If you get the off set bushings they give you a better camber for turning.
I wouldnt go with urathane bushings, some might say different but I think they give a harder ride.
And if you want to spend 600$ m3 aluminum arms are always a plus.
Old 03-02-2008, 07:23 PM   #4
kenika65
kenika65's Avatar
Your Ride: 91 m42, 86 2.7i, 89i parts car
With your set-up go urethane. I put two sets of OEM rubber on and they both went bad in 60,000 so I have these, which is what you need.
http://www.bavauto.com/shop.asp
As for aluminum control arms get e36 aluminum.
Old 03-03-2008, 11:49 PM   #5
mzbmw325i
mzbmw325i's Avatar
thanks for the feedback guys, i might go with 96 M3 bushings, they don't require alignment afterwards.
has anyone tried any of the bushings from below vendor, certainly they look interesting.
http://www.akgmotorsport.com/
vB code is On
130 thousand mile control arm Picture Numark318i Tire, Wheels And Suspension Forum 7 12-07-2007 06:23 PM
tough time with control arm maximk2 Tire, Wheels And Suspension Forum 10 10-30-2007 01:48 AM
RTAB (Rear Trailing Arm Bushings) orientation zipwax Tire, Wheels And Suspension Forum 0 10-03-2007 03:40 AM
The Control Arm murderer Numark318i BMW General Discussion 8 07-12-2007 08:18 PM
