Old 03-02-2008, 11:04 AM   #1
Neilsen
Neilsen's Avatar
Rate My Car: 226 / 337
Your Ride: 1990 BMW 325i
overheating at idle
today as i was going through a drivethrough, i had to sit idle for a little while and by the time i was out. my car had overheated to the top of the meter. what is wrong and what do i need to replace? any ideas?
Old 03-02-2008, 11:40 AM   #2
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
Check your t-stat and your clutch fan. I'm having the same problem right now when I'm at idle or running in the city. Also check if you have any kind of coolant leak and also check that your water pump is working.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 03-02-2008, 06:39 PM   #3
Neilsen
Neilsen's Avatar
cool, my sensors do say check engine oil and check coolant but weve checked and there is plenty of coolant and oil. other than that, i am having the same problem
Old 03-04-2008, 11:20 AM   #4
HyeTide
HyeTide's Avatar
Had same problem, check your electric fan, make sure it turns on when temp. rises?
Idle vibrations E39 540i lacikam E12, E28, E34, E39, E60 15 10-24-2011 11:47 PM
E34 Idle Issues hartge h26 E12, E28, E34, E39, E60 1 11-01-2007 09:34 AM
Cold idle vs Running idle Jami318is E21, E30 3 06-27-2007 01:56 PM
Overheating problems! Oh my! digismack E36 24 01-06-2007 11:05 PM
325i Idle Control Valve Jammer3 E21, E30 1 07-14-2006 09:29 PM
