Old 02-25-2008, 05:34 PM   #1
turbolesstom
Your Ride: 2000 VW Golf
Need some advice: Repair costs.
Hey all, I've found another possible E30 to buy. I went and looked and it today. Drove it around as well. Here is a link to the ad: http://minneapolis.craigslist.org/car/582394606.html
So the engine rebuild is credible (saw paperwork) and there is alot of documented fixes throughout the years. The car does idle/run rough, seems like its going to need a distributor cap and plugs. The steering was very notchy and jerky, Im guessing either bad suspension pieces or possible steering rack? The shifter was tight, and the clutch felt good. Interior is not bad, drivers seat has some tears but overall i would say 7/10. The body however, needs alot of work. Both fenders are shot, and there is alot of surface rust and dents. the glass trim needs replacing. Tires are almost bald. The IS lip was pretty much done for.. chunks missing and whatnot. So, with that being said, what I am looking to spend on repairs?
2 Fenders
distributor/plugs
possible steering rack/tie rods etc
IS front lip
Honestly, I dont think I would pay more than $900 for it, just because the body is in such bad shape.. What are your thoughts?
Thanks much.
EDIT: If you cant see the link:
87 325IS.
240K on the body,
45K on engine rebuild.
upgraded ecu (524) and 19lb injectors
Old 02-25-2008, 05:49 PM   #2
Rate My Car: 84 / 337
Link won't load
Old 02-25-2008, 05:55 PM   #3
turbolesstom
edited main post with car's vital info for those that cant view the link.
Old 02-25-2008, 06:09 PM   #4
Dr1ve4fun
Rate My Car: 235 / 337
Your Ride: 1985 325e
That car looks like it needs quite a bit of work. If you want a project it would probably be great, but I would still try and find something that has a better body and interior. Living in AZ I have never seen a car that has so much rust. IMO it's not even close to worth $1350 and I don't think I would even pay $900 for it. I don't know how much the parts would cost, but more then likely it is cheaper to get an E30 that is in better shape.
Old 02-25-2008, 06:13 PM   #5
Dr1ve4fun
Here are the pictures that the guy posted of the car. What does everyone else think?
Old 02-25-2008, 08:40 PM   #6
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Not worth the $1350 hes asking, with all that rust, I bet the gas pedal never gets stuck from that matt either... If you can get it cheap it might be worth it, that said the cost of the repairs and not really having a good idea on what it might need might not make it a good idea. What is your budget between repairs and buying the car, you might be better off trying to locate a car that is in better shape and save yourself some money in repair work.
Old 02-25-2008, 11:49 PM   #7
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
id pass on it too. maybe if you can get it for around $600, but i personally wouldn't want to take on a daily driver that is also a rebuilding project.
Old 02-26-2008, 03:30 AM   #8
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
I wouldn't do it either. I can tell you that the rough idle is becuase they probably didn't ease the injectors so the ECU would compensate for the added fuel going in and also didn't add the more airflow coming in to better the performance of the bigger injectors. I just went thru this last week when I added bigger injectors, but I also added a bigger AFM and intake. I would definetly pass on it. There are far better cars that I've seen on other forums that are worth a little more but are very well kept and for a pretty good price.
Unless you want to be busting your butt on this one
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 02-26-2008, 09:03 AM   #9
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
no
Deus ex machina
E30 325i Touring
Old 02-26-2008, 07:34 PM   #10
turbolesstom
I offered $650. Pretty low-ball for what he's asking but we'll see what he says..
Old 02-26-2008, 08:21 PM   #11
iamcreepingdeath
iamcreepingdeath's Avatar
it's worth it for around $700, if the engine really is good. I am worried about the rough running. It could be a small fix or a seriously bad problrm that would take insane amounts of work to get to.
be careful about stuff like that
1999 528i Maintenance costs jsnoland E12, E28, E34, E39, E60 3 11-28-2007 12:03 PM
Torn strut dust cover repair? jerryd E12, E28, E34, E39, E60 0 05-03-2007 09:05 PM
Service Repair Video's ????? 325is_Frank Video and other Multimedia 0 10-08-2006 07:42 PM
Need advice - want to buy 98 528i patrickjoseph E12, E28, E34, E39, E60 2 05-30-2006 05:29 AM
Looking at 528's . . advice? Dudesky E12, E28, E34, E39, E60 8 04-05-2006 08:43 AM
