Old 01-25-2008, 02:44 PM   #1
Dr1ve4fun
Rate My Car: 235 / 337
Your Ride: 1985 325e
Power Sunroof
My sunroof wont open! It makes a really fast annoying clickingish sound. I got it to close and it will rise up a little too, but it's nice out today and I want it open. Is there a way to open and close it manually?
Old 01-25-2008, 02:59 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Get the crank one, non power FTW, I have mad sunroof opening skills now. Sounds like whatever drives it isn't catching, i'm guessing the clicking means that the motor is running.
Old 01-25-2008, 06:14 PM   #3
Dr1ve4fun
How can I change it to a crank?
Old 01-25-2008, 07:28 PM   #4
nick_318is
nick_318is's Avatar
I havent any idea I just know that it can probably be done since a power roof was an option and I have the manual roof on mine.
Old 01-25-2008, 07:55 PM   #5
253325is
253325is's Avatar
Your Ride: 1987 325is
sunroofs are bitches! the motor for mine is shot and am having the hardest time finding a new one but anyway from this i know you can open and close it manually using an allen wrench... unless you already knew this and something far worse is wrong with it that i dont even know about... but on nice sunny days when i wanna show off my car i bust out the allen and crank that bitch open cause i dont think i'm ever gunna figure out how to fix mine ha.
Old 01-25-2008, 09:51 PM   #6
Dr1ve4fun
Thanks
Old 01-26-2008, 07:05 AM   #7
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
changing the sunroof to manual or doing any work on it is a real hassle
you have to take out the headliner...
Deus ex machina
E30 325i Touring
Old 01-26-2008, 04:54 PM   #8
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
^^^ and you would probably need a new one or need to fabricate something because the crank one has a huge hole where the crank goes, and the electric has just a small hole for the button!
Old 01-26-2008, 08:18 PM   #9
Exilion
Exilion's Avatar
Your Ride: 1991 325i
But other than that it'd work! Actually it would probably take quite a bit of fabrication. I'd imagine you would have to cut out the hole for the crank and then you'd have to figure out a way to support the crank properly in the automatics old space. I'd imagine the pulley system and all that would be the same though.
Old 01-27-2008, 08:05 AM   #10
jcjdavis1
jcjdavis1's Avatar
Your Ride: 1989 320i tourer
Electric Sunroof
Hi I got this of the E30zone.net it might help a bit.
One of the cables has jumped on the main drive sprocket on the motor.
Unscrew the three bolts that hold the motor assembly in place and drop the motor down. With luck you may be able to re-time the roof by moving the cables along with a screwdriver, or get the roof into the positions it needs to be in to remove the steel panel.
Still leaves the problem of what went wrong in the first place, of course. You may have damaged one of the cables and/or the drive sprocket.
The older I get the wrong bits get stiff!!!
Old 01-27-2008, 12:50 PM   #11
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
Don't cut nothing. The plates for the manual and the electric are totally different and you wont be able to adapt a crank on it. If your motor works right it might be your cables that move it and for that you will have to remove the whole sunroof because the cable tensions are different tension from the manual ones.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
F*** the sunroof!!! akinthecat E36 7 03-15-2007 11:45 AM
Power Sunroof elsabor67 E21, E30 0 01-25-2007 03:23 PM
weird CEL... ivopivo E36 46 03-22-2006 01:22 PM
How do I remove headliner for sunroof install? Beater_Bimmer E36 2 08-14-2005 11:37 AM
Microsoft Power Supply komodo Comedy Collection
1 07-13-2005 06:30 PM
