Old 01-06-2008, 05:22 PM   #1
dark_islight
Warm engine start
My 1991 e30 318is was having a problem when starting after it had been parked with the engine hot for more than 15-20 mins.
Symptoms were as if it had no fuel in the line. Cranked over 6-8 times and then stumble and start and run fine.
I did research on the internet and found that similar problems had been posted on other BMW websites. see: http://www.bmwe34.net/E34main/Trouble/535ihot_start.asp
I never checked with BMW in Canada for availability.
Note: The repair kit is inexpensive but costs more than its worth in shipping.
Bulky packaging. Kit consists of the replacement fuel line with the check valve already attached (you will cut this to length for your application) and some new clamps (crimped type clamps you may wish to replace with screw type clamps) and some insulation tubing and plastic nut covers (this can be discarded as you may not use this for your repair)
I finally had enough and I purchased BMW check valve p/n 16149068988 from Steve Haygood in the states. You can see his site at http://www.stevehaygood.com:80/
Pre install
Post install
Car starts without hesitation now!!!!:
dark_islight
Old 01-06-2008, 05:26 PM   #2
elsabor67
elsabor67's Avatar
Rate My Car: 58 / 245
Nice, looks pretty simple.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 01-06-2008, 06:27 PM   #3
nick_318is
nick_318is's Avatar
Title: Road Kill
Rate My Car: 4 / 245
Nice work, more e30 pictures!
Old 01-06-2008, 08:13 PM   #4
dark_islight
Warm engine start
Important Note: Do this outside not in the garage!!!!
Very simple. Disconnect the fuel pump power supply and fuel sender connectors. Takes 30min, just have everything ready, Clamps, tools, fire extinguisher and pre cut the fuel hose before you disconnect the feed line.
Be prepared for some fuel to leak back down towards the fuel pump, have some rags handy.
dark_islight
Old 01-19-2008, 04:07 PM   #5
dark_islight
Update: This inexpensive repair absolutely solved my warm start issue.
dark_islight
vB code is On
OK - getting codes, CHECK ENGINE light works, but it's not on! volvodefector79 E36 1 11-13-2007 06:46 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 11:34 AM
Car stalled and now engine won't turn over... looking for any ideas/help komodo M3 21 05-23-2006 12:15 AM
15 Things to do in Wal-Mart komodo Comedy Collection 4 10-05-2005 12:37 PM
