Old 11-27-2007, 01:11 PM   #1
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
Car won't start
This is my problem.........
Yesterday I got home and shut the car off. Everything fine and no problems. When I went to start up the car after an hour it just cranked and when it turned over it acted like it was barely getting fuel. Today, after getting a fuel pump, I decided to check the power going to the pump and there was none. I went to check if it was getting a spark at the wires and no spark either. I ran the diagnostics and shows me a 1444 code(no faults) and am sorta stumped now. Does anyone have a guess as to what it could be???? Thanks.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 11-27-2007, 01:16 PM   #2
Rate My Car: 84 / 337
That seems like a central electrical problem, like some main central fuse?
Old 11-28-2007, 07:38 PM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Check you pump relay before replacing the pump.
If it only happened once I wouldnt do anything untill it happened again.
Old 11-29-2007, 02:58 AM   #4
elsabor67
elsabor67's Avatar
On the pump, is it supposed to be getting juice when the car is starting or when you turn teh key to the on position (al dash lights on)?
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 11-29-2007, 03:08 AM   #5
n3dsd
Your Ride: 325ic
yes
Old 11-29-2007, 04:11 AM   #6
elsabor67
elsabor67's Avatar
Yes on both?
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 11-29-2007, 12:27 PM   #7
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
Heh its the same issue as my e30. I was told that its the ecu on e30s have issues.
Old 11-29-2007, 12:36 PM   #8
elsabor67
elsabor67's Avatar
Finally some...........
Progress
I was told by some friends to check my Crank Position Sensor because it sends a pulse to the ECU so it can tell the ignition to spark. So I got a new CPS and walla, spark at the plugs. After that victory, I started tracing the power for the pump and finally traced it to the pump just gave up out of the blue. A friend is pulling one for me tomorrow morning. Hopefully that solves my problems for now. WIll keep you posted as to what happens when I change the pump tomorrow. Thanks for the help and advice guys.
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 11-29-2007, 03:04 PM   #9
Exilion
Exilion's Avatar
Your Ride: 1991 325i
Good to hear you're making progress hopefully it's just the fuel pump now.
Old 11-30-2007, 05:40 PM   #10
elsabor67
elsabor67's Avatar
I Am Now..........
M.C. (mission complete) After some further checks I realized with the help of some friends that E30 fuel pumps don't come on until you start cranking the engine. The pump seized. Got one today and she is finally running. I appreciate the help from all. Thanks
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Help me please!! My car does not start... Alin E36 4 06-29-2009 08:48 PM
Money Shift Information bimmersunited BMW General Discussion 1 12-23-2007 05:08 PM
Car Cranks but wont start? NewBIMMERfan85 7 Series (E23, E32, E38, E65, E66) 11 04-15-2007 11:07 PM
1991 325i Vert...Tastefully Modified and in great condition! 325i Vert Bmw Cars For Sale/Wanted 3 09-17-2005 09:28 AM
