Old 11-26-2007, 12:47 PM   #1
player2poet
Your Ride: 1985 bmw 325
sloppy tranny
ok heres the scoupe ive been driving my 85 e30 one with all m3 mods ect .anyway i need to know if anyone has had this problem and if there is away to fix this or if my tranny is shot .when you try to put it into reverse the shift lever hits the side of the center console seems like revers is way to far over to the left when you get it over it goes right in and stays no problem with it coming out of gear .second problem it goes thru all the gears like butter and stays in to all gears no grinding nothing .just that even when in gear the shift lever just flops around very sloppy is it new tranny time or is there a shift link bushing that may be out or somthing ? trannys are not my thing at all any feed back would help
Old 12-04-2007, 02:33 PM   #2
player2poet
really guys no input at all first time i got no responce at all anyways it ended up to be the shift rod bushing where shot got a after market double ended rod with urithan bushings.now the fun part putting it in .
Old 12-04-2007, 03:53 PM   #3
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
I have been busy with work so I missed this, I would try the bushings for the slop problem. As far as reverse goes I hit the side of my console every time.
Old 12-04-2007, 03:58 PM   #4
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
It's not fun to change, I did my SSK and it became a major pain to reach and get up in that area with the car on a lift. On another note, are you still selling your MSD 6al?? Sent you a PM but no answer.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 12-04-2007, 04:55 PM   #5
player2poet
yup its still for sell if you want it
Old 12-05-2007, 01:29 AM   #6
elsabor67
elsabor67's Avatar
Yes I do. I sent you a PM. Let me know. Thanks
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Which Tranny fluid for my car? davidbise E46 4 12-04-2007 06:56 AM
Tranny Trouble clarkstreet 7 Series (E23, E32, E38, E65, E66) 1 10-04-2006 08:23 PM
E34 540i6 bad tranny output shaft bearing.... Baldingo540 E12, E28, E34, E39, E60 12 05-24-2006 08:48 AM
Found a used Tranny (long post) dinan540 E12, E28, E34, E39, E60 35 03-21-2006 03:28 PM
Need Auto Tranny Recommendations 1fast325i E36 5 03-09-2006 12:40 AM
