Old 11-25-2007, 12:52 PM   #1
dev6315
dev6315's Avatar
Your Ride: 1989 325is
Fuel Injector Project
Hi again. I was able to get a great deal on 6 new 19lb injectors. I was planning on doing some other projects at the same time. Like paint the intake manifold and valve cover, change the fuel filter, clean everything up etc. My questions is, has anyone else tackled this with some pointers to share?;and what are some other good things to replace or clean while I am doing this? and dooes anyone know the gasket list I should buy? Thanks in advance!!!!
1989 325is ///
Old 11-26-2007, 06:39 AM   #2
n3dsd
Your Ride: 325ic
hi
I have done this recently and found you need a day to take out and replace all the parts.. you need new gaskets for the throttle body and the inlet manifold ..you might get away with the rocker cover manifold..The manifolds can be painted with 2 pack paint and a pro lacquer..its better to get spares and paint before you start dismantling
oh yes and spare 10mm sockets for when you lose one down the engine
Check your fuel lines for cracking and remember to fit them the right way up..you have to take off one of the coolant lines to get at one of the manifold nuts The breather tube that goes from the manifold to the block has a spring which has to be compressed before replacing ..use a plastic tie which you cut when in position. Whilst you have the manifold off clean the electrical connector plug ..you might not have another chance
take pics to remind you of what goes where
as to 19lb injectors, I had no probs with the 17.5lb ones but have you done anything else t the car if s they wont make any difference apart from probably overfueling
Old 11-26-2007, 12:14 PM   #3
dev6315
dev6315's Avatar
Thanks for all the great info. I am probably going to go the route of buying spares and doing the paint work beforehand like you mentioned. As far as upgrades, I currently have a cold air intake system, and will be upgrading the plugs wires and plugs.
Will 19lb injectors hinder performance or hurt the car in anyway. I dont currently have a chip installed. I dont of course want to damage anything...thanks again!!
1989 325is ///
Old 11-26-2007, 02:18 PM   #4
dev6315
dev6315's Avatar
Does anyone have any info on upgrading to larger injectors? Goods and Bads....Thanks
1989 325is ///
Old 11-26-2007, 03:32 PM   #5
n3dsd
Your Ride: 325ic
according to the infamous Jordan you might over-fuel with 19lb and they certainly will not increase the performance..might be ok if you were going to turbocharge..I put in 17lbs and have had no probs but I have bb throttlle body 6 branch header and a maf
Old 11-26-2007, 07:52 PM   #6
dev6315
dev6315's Avatar
Ok, well Im not going to hurt the performance of an already perfectly performing car. I usually research upgrades to a T, but these were kind of an impulse buy. I will turn around and sell them.
Now, what is the DIY procedure for cleaning your existing injectors? I know they have quite a few miles, if not all 142,000 on them. I'm sure just a cleaning will improve some performance. I will buy replacement o-rings and such. n3dsd, your help is greatly appreciated, you saved me a lot of headaches, anymore more pointers you have are def. welcome. Thanks again!!!!!!!!!!!!!!!
1989 325is ///
Old 11-27-2007, 03:35 AM   #7
n3dsd
Your Ride: 325ic
I just used carb cleaner..tried to soak then inside and out.. and make sure you have a box handy for the nuts and bolts that seem to disappear...one of those magnetic probes for retrieving from down the engine is also handy.
If you want fit the 17lb injectors as they give no problems as you won't want to do this job again
mine now looks like this
http://img100.imageshack.us/img100/5874/cimg0769ss3.jpg
Old 11-29-2007, 02:52 PM   #8
dev6315
dev6315's Avatar
n2dsd, where did you get your 17lb injectors. I am looking to buy either new or good rebuilds. Thanks
1989 325is ///
Old 11-29-2007, 05:29 PM   #9
n3dsd
Your Ride: 325ic
they are actually 18s. green ones from a 93ish e34 or e36 part no 13641730060 (...they could be 18lb injectors 0 280 150 415bosch)
this site might be of help
http://users.erols.com/srweiss/tableifc.htm#BOSCH
Help With Fuel pump and no power!!! POS_BMW E36 7 11-27-2009 10:14 PM
Fuel pump zeaq328i E36 12 04-28-2007 12:08 AM
Fuel filter change akinthecat E36 12 08-19-2006 09:55 AM
