Old 11-10-2007, 08:14 PM   #1
dev6315
dev6315's Avatar
Your Ride: 1989 325is
Heat blower question???
I have an 89 325is with 4 speed settings for the blower fan. Other than a resistor (which I swapped out and didnt work, but it was used so that one could have been bad), what else could cause the blower to only opperate at full strength? Setting 1 through 3 do not opperate. Thanks in advance for any insight.
1989 325is ///
Old 11-10-2007, 08:37 PM   #2
Rate My Car: 84 / 340
My car did that too, it was the resistor. Maybe the one you got is bad.
Old 11-11-2007, 08:45 AM   #3
dev6315
dev6315's Avatar
Thanks, I will stop being cheap and buy a new one...
1989 325is ///
Old 11-11-2007, 08:47 AM   #4
Rate My Car: 184 / 340
the switch itself?
Old 03-10-2008, 07:49 AM   #5
Exilion
Exilion's Avatar
Your Ride: 1991 325i
Alright I had the same problem and after using checking voltages I found that it was in fact the resistor. However the physical resistors on the unit seem fine so I was wondering how the switch thing mounted at the bottom of the board worked and if it could be repaired. Maybe I'm being cheap but it doesn't seem like anything else is broken and I already cleaned all the contacts and whatnot so that's the only questionable part left.
EDIT: In general if number four works that means you have full voltage to your blower motor. The resistors are on a separate circuit which generally means a bad resistor. If say 1 or 2 out of the 4 work then it would more likely be the switch.
No heat. I NEED heat! M.C. Sketuls E21, E30 9 10-22-2007 06:53 PM
Blower Resistor Vik E36 3 09-17-2007 04:00 PM
Airplane Flight Question komodo United Off Topic  **FOR MEMBERS ONLY** 105 07-27-2007 09:35 AM
Squealing Blower Motor '01 525i Boxer19 E12, E28, E34, E39, E60 0 02-27-2007 10:11 AM
No heat, no AC, No defrost/defog?? Alpine328i E36 10 05-28-2006 09:53 AM
