Old 11-10-2007, 06:49 PM   #1
mzbmw325i
mzbmw325i's Avatar
Question coolant flush question
planning to do a coolant flush on the 88 is E30 tomorrow. basically what i want to know is if i have to have the heater controls on when i flush and refill the system? do i turn the heater off after the old coolant is flushed?
thanks
Old 11-11-2007, 11:41 AM   #2
StiffCookie
StiffCookie's Avatar
Your Ride: 1992 320i SE
Hi,
I only use the blower on full hot when bleeding the rad on my e36. I always thought it was to slow overheating of the engine while your getting the air out of your system with the engine running.
Correct me if I'm wrong though anyone.
Hope that helps
Old 11-11-2007, 05:23 PM   #3
Rate My Car: 183 / 337
Originally Posted by StiffCookie View Post
Hi,
Hope that helps
its actually to circulate the coolant that is in the heater core so you can get all the air out of the system
Old 11-16-2007, 03:43 PM   #4
jcjdavis1
jcjdavis1's Avatar
Your Ride: 1989 320i tourer
Hi If you are having problems with air lock try this-
Engine running
Heater controls set to hot
Header cap off
Keep squeezing all water pipes watching for air bubbles
Top up coolant as required
When satisfied no air put header cap back on
Release bleed valve on thermostat housing and check that no air and only coolant is coming out.
Do this after your system flush.
The older I get the wrong bits get stiff!!!
E39 Faq.... Dan E12, E28, E34, E39, E60 63 12-02-2010 09:05 PM
Coolant Leak, Fuck (long post) dinan540 E12, E28, E34, E39, E60 13 03-22-2008 12:25 AM
Overflow Coolant cap on E36 Mercenary(FH) E36 10 04-06-2007 10:31 AM
Coolant Question Nics E46 5 05-02-2005 11:20 PM
Coolant Flush komodo E36 7 04-27-2005 09:48 AM
