Old 09-24-2007, 09:10 PM   #1
mzbmw325i
mzbmw325i's Avatar
Exclamation left front/wheel side issue
Ok, i now this will be repeating but i am starving and i want to get this concern out of the way.
The issue is on my 88 E30 325is. When i am driving slowly and going over uneven parts on the road, i can hear this clunk like noise coming from the front left wheel. When i drive on the freeway and need to come to a sudden stop i can feel the left wheel shaking when i apply the breaks and it feels like the breaking power on the left wheel is a tad weaker due to the shake.
is that a bad bearing, rotor, etc. let me know..and may the force be with you all
Old 09-24-2007, 09:12 PM   #2
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Control arm. Or Control arm brushing.
Should be like 200 dollars... Do you DIY?
Old 09-24-2007, 10:21 PM   #3
mzbmw325i
mzbmw325i's Avatar
i recently replaced both control arms, tie rods and front struts, got alignment too.
the sound is annoying, i can hear the clunking at slow speeds, once i am going fast on the freeway i dont since the road is even and all the other noise.
i have been reading the front bearing posts here and i am thinking it might be that, how can i be sure is the bearing, i removed the tire and moved the rotor but did not feel any play.
Old 09-24-2007, 10:48 PM   #4
RSF5
RSF5's Avatar
Snap.... So you've check the rotor to make sure it isn't warped? other than that the only thing I could think of is wheel bearing.
Did you jack it up and spin the wheel?
Old 09-24-2007, 11:01 PM   #5
Rate My Car: 183 / 337
strut mounts?
EDIT: i see you replaced your struts, did you tighten them properly and seat them correctly?
Old 09-24-2007, 11:05 PM   #6
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
Have you checked the rear subframe bushings? I used to have a clunking noise on my previous E30 and when I checked it thinking it was the front, turned out to be the rear bushings. Also look at the front struts to see if they are on good.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 09-25-2007, 01:29 AM   #7
straight6pwr
Rate My Car: 26 / 337
another possibility (although its probably not likely): check the collar on the strut tube that holds the strut in place. if it come undone (ive heard of this before) it will clunk around pretty bad.
Old 09-25-2007, 10:28 AM   #8
mzbmw325i
mzbmw325i's Avatar
Originally Posted by xsperf
strut mounts?
the mounts looked fine so i did not replace them, the rotor looked fine, not warpped, there is no play as far as i know.
if the strut is not seated properly or loose perhaps would that explain the shaking of the wheel when i slam on the breaks.
i mean coming from a high speed i can really feel the left wheel shaking, the right is just tight as a rock.
thanks for all the input everybody.
i am going to dismantle the left strut this weekend and see how the strut is seated.
Old 09-25-2007, 10:38 AM   #9
mzbmw325i
mzbmw325i's Avatar
i doubt is the rear bushings, i mean i can feel the shaking when breaking coming from the front left wheel, also the clunking is pretty noticable at low speed going over uneven pavement or pot holes.
i am leaning toward the strut's seating now, will chek on it . thank u
Old 09-25-2007, 09:24 PM   #10
mzbmw325i
mzbmw325i's Avatar
Update!!!
i fixed it..for now it looks like.
the bolt on the strut (that sits on top of the mount) wasn't tight enough, now there is no clunking or shaking when i hit the breaks, smooth as a ship. thanks everybody, that's why i like this community, cheers
Old 09-25-2007, 09:39 PM   #11
Rate My Car: 84 / 337
Oh that's great to hear!
Old 09-25-2007, 10:31 PM   #12
RSF5
RSF5's Avatar
great man! hope it does awesome!
Old 09-25-2007, 11:39 PM   #13
elsabor67
elsabor67's Avatar
Happy for you man
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Left side rear wheel clunking noise ?? jonni325 E36 10 04-13-2007 07:34 AM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 12:05 PM
HELP! Dealership wants $450 for ABS left wheel sensor!!! delmarco E36 5 07-17-2005 02:03 AM
Slow Cars in the Left Lane komodo United Off Topic  **FOR MEMBERS ONLY** 36 06-17-2005 02:09 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
