Old 07-09-2007, 11:01 AM   #1
rb325i
Your Ride: 1987 bmw325i
help with starting issues w/325i
I have a 325i "87" and having trouble getting it started. It will rotate but will not fire.
Old 07-09-2007, 12:48 PM   #2
Rate My Car: 84 / 337
I'd start with the fuel pump. How old is the ignition system?
Old 07-09-2007, 01:55 PM   #3
stevo
Your Ride: 1997 318se Touring
is there a spark at the plugs?
Old 07-09-2007, 02:08 PM   #4
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
Check to see if you have the following;
1. Fuel going to the rail
2. Spark at the plugs and wires (it will give you the jolt of your life if you're not careful)
3. Pop your distributor open and check both the rotor and the distributor for wear and tear.
4. Loose, frayed, or dry rotted hoses, vacuum lines, etc.
If I think of more I'll let you know. Good luck.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 07-09-2007, 05:19 PM   #5
Rate My Car: 183 / 337
do you hear any combustion at all or is it just something spinning freely, and did you just get this car and its not starting, or have you been driving it and all of a sudden one day its not starting(i would suspect fuel pump relay in that case)
Old 07-09-2007, 05:34 PM   #6
Rate My Car: 137 / 337
do you have any documents stating that timing belt was replaced?
Old 07-15-2007, 05:19 PM   #7
rb325i
Do you consider the computer as part of the ignition system because I'm not getting any fire to the plugs?
Old 07-17-2007, 11:59 PM   #8
bmdude
Your Ride: BMW350
it could be that you have a bad *no spam - everyone here knows how to find BMW parts bmw spark plugs* try also checking the ignition module, pump, and starter.. by the way, have you done tune up, lately?
need help with engine starting Reddots89 E36 3 05-04-2007 06:31 AM
MAJOR PROBLEM - Starting Car!!!! HELP!!! projal147 E36 12 09-07-2006 11:18 AM
1995 325i - Starting Issues scrichy84 E36 15 03-22-2006 05:58 PM
im having hardware issues... e30boarder Geek Chat 15 08-08-2005 03:09 PM
Trouble starting car after sitting cold for 3 days..help!? delmarco E36 2 05-28-2005 09:26 AM
