starvin for fuel
ok here we go. my 1990 325i is missing at idle and randomly through driving loads. i have changed the plugs, wires, cap, rotor, fuel filter, fuel injectors, all with no joy. any suggestions any one. it feels like its starved for fuel and it gets worse aS the engine heats up. .....HELP PLEASE!
throttle position sensor? fuel pump?
maybe oxygen sensor or vacuum leaks?
Possibly time for a new fuel filter?
ok as i said earlier i just changed the fuel filter and to my knowlege of dead fuel pumps they just quit as was the case with my ix and my e38. but whho knows. the throtle position sensor seemed to check out alright aswell
Maybe there is a leak allowing air into the fuel lines, or some small debris in the fuel tank blocking the flow a bit
check ALL your vac lines for cracks (including Bellows tube) also try cleaning your MAF sensor. It could also be signs of a fuel pump going bad - they do get weak w/age. And believe it or not the seal on your gas cap can cause the symptoms you described.
| All times are GMT -5. The time now is 08:52 AM. |
