Old 06-15-2007, 11:10 AM   #1
talus22
Driving without power steering
Is it ok to drive my 88 325 without any power steering fluid in the pump...
It is leaking heavily and I am getting rid of it soon for a new car but I was wondering is there any danger of the steering seizing up or anything like that?
Old 06-15-2007, 11:20 AM   #2
stevo
Your Ride: 1997 318se Touring
it will make the steering very heavy and consequently will make the car difficult to handle especially at low speeds, you could be putting yourself and other road users at risk, in answer to your question, no its not ok but its entirely up to you.
Old 06-15-2007, 12:23 PM   #3
craig
craig's Avatar
Title: Sitting in Time out
yeah dont worry about it, my truck has no power steering and i can turn just fine. its just that you will get a mild workout turning from a stop.
Old 06-15-2007, 12:28 PM   #4
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
I wouldn't do it. You might damage more than what you think and also take the risk of an accident since the responsiveness is not there.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 06-15-2007, 01:01 PM   #5
drz
Title: local dumbass
Rate My Car: 34 / 340
Your Ride: E36 2.8i
Just top off the fluid reservoir. Cheap, safe, and effective. Without fluid in the system, you will ruin the pump, which will cost a lot more to fix than it will to top off the fluid frequently.
Edit: to properly top off the system, first fill the reservoir to the fill lline, then go back in teh car and turn the wheel lock to lock. Then check the reservoir again and add fluid as necessary. Turn the car on, turn the wheel from lock to lock, then turn off and check level again. Repeat until level in reservoir remains at the fill line after turning the wheel from lock to lock.
Old 06-29-2007, 08:17 PM   #6
Red_Rocket
Red_Rocket's Avatar
Rate My Car: 213 / 340
Your Ride: E30 325
there is nothing wrong with driving around with power steering, you are not a danger to anyone....shit, tons of people on the road don't have power steering as an option on their cars....
I wouldn't leave the belt on there if there is no fluid in the pump, you can ruin it. Just adjust the tension on it and just slip it off, you might have to take the AC belt off first though....not hard to do at all
Power Steering Fluid Showing on the VDO Jimmie34 E12, E28, E34, E39, E60 4 05-09-2007 09:15 AM
Power loss while driving dbrdrck E21, E30 6 02-09-2007 02:26 PM
Power Steering Loss-help!!! tonyvt328is Tire, Wheels And Suspension Forum 2 01-31-2007 08:33 AM
Power Steering Loss-help!!! tonyvt328is Tire, Wheels And Suspension Forum 0 01-22-2007 12:44 PM
Power steering. catalyst E36 4 07-26-2005 12:04 AM
