Old 05-26-2007, 02:39 PM   #1
crisby325i
Rate My Car: 212 / 340
Your Ride: 1988 BMW 325i Convertible
clutch problems..
So i was going down the road today about an hour ago and i was at a stop light. when i tried to accelerate once it turned green, my clutch was stuck as far back as possible to the floorboard and i could not bring it out. once i was finally able to pull it back to normal, i luckily managed to make it about 30 feet in neutral to a gas station. i believe it was my throwout plate for my clutch. once i was parked i played with it a little bit. i pulled my clutch out a bit and then i pushed it maybe an inch or two and it pushed it's way all the way down to the floorboard again. i haven't looked at any parts but what would i need to get? throwout bearings? any help would be appreciated. thank you.
(OO=[][]=OO) It's all about the round lights...
Old 05-26-2007, 03:11 PM   #2
XGiWITHA323i
XGiWITHA323i's Avatar
Rate My Car: 78 / 340
Your Ride: 1979 323i
You are going to have to drop the tranny and take a look. It sounds like for some reason the fork is getting stuck...probably on what's left of your throwout bearing. If I had to guess a new clutch, thowout bearing, and pressure-plate are now on you christmas list.
Good luck.
Old 05-26-2007, 07:02 PM   #3
Rate My Car: 106 / 340
No, it's not your fork, nor your throwout bearing. If it was, you'd hear scraping noises. The slave cylinder's piston rod only pushes the fork forward, but the piston rod and fork are not actually connected together. Therefore, the fork can't possibly hold the pedal from returning back. Check for clutch fluid leaks. Either your clutch master or slave cylinder is the culprit- one of them probably has to be replaced. Or maybe you'll get lucky and it's just air in the system. In that case you'll need to bleed the clutch hydraulics.
Old 05-27-2007, 02:37 PM   #4
XGiWITHA323i
Didn't think about the pedal not returning you got me there, (thanks for the correction) however; I can tell you from experience, as I just had this happen, you don't always hear scraping. In fact you don't necessarily have to hear anything. Just depends how stuff breaks.The only good news I had was that my slave cylander was ok....everything else was trashed.
Old 06-03-2007, 09:44 PM   #5
crisby325i
haven't had a chance to look at it yet. been real busy this past week. thanks for the quick responses. i saw them, just didn't get a chance to respond. anyways, i'm going to check it out this week. hopefully i can find a diagnosis soon...
FAQ: How the clutch operates Dudesky BMW OEM Parts Department DIY's & FAQ's 10 07-09-2006 11:25 AM
Clutch slipping? Tochenzo E36 41 02-21-2006 02:29 PM
Clutch Issue? dinan540 E12, E28, E34, E39, E60 19 10-24-2005 12:05 PM
Clutch Install pics! 56k...nah devinwwu E12, E28, E34, E39, E60 4 08-04-2005 04:34 PM
Just ordered a LW Flywheel and Stage 3 clutch devinwwu E12, E28, E34, E39, E60 5 08-02-2005 11:40 AM
