Old 05-14-2007, 08:44 AM   #1
NIZAAM
Your Ride: 1990
Tappets / Cut Out
My Cars Tappets Makes Alot Of Noise I Recently Changed The Ecu Because The Car Was Cuttung Out @ 5500 Rpm
But No Change It Cuts Out @ 6000 Rpm At The Moment Any Sugestions
Old 05-14-2007, 09:55 AM   #2
theSMELSINATOR
theSMELSINATOR's Avatar
Your Ride: 1990 325iX
E30 engines are generally just loud engines. you may want to look here to see if this is the same thing that you are describing: http://www.unitedbimmer.com/forums/e...ggestions.html
Old 05-17-2007, 05:27 AM   #3
NIZAAM
Your Ride: 1990
Cool
I replaced my ECU because my revved to 5000rpm and now it only goes up to 6000 rpm do you think the car needs to be set or can i do something myself to fix the problem
Tappets when cold? bmwISCoupe E36 5 03-26-2007 05:04 AM
E36 Clear Tails? Diamond Cut or Euro OEM style? delmarco E36 6 09-14-2005 04:36 PM
Cut meself!!! (NWS'ish) Beelzibub United Off Topic  **FOR MEMBERS ONLY** 12 08-15-2005 11:09 AM
