Old 05-08-2007, 05:06 PM   #1
DBB
Your Ride: 1985 325e
Acceleration lags
my 325e has a pronounced hitch in its acceleration. gears 1-5. still gets up to speed alright...feels like timing, plugs, wires, fuel injection? wires look ok, not experienced finding vacuum leak. what do i do?
Old 05-08-2007, 05:15 PM   #2
stevo
Your Ride: 1997 318se Touring
start by getting the car serviced or do the service yourself making sure you use the correct grade and gapped spark plugs, new bmw spec air filter, use a good injector cleaner additive (redex) or similar, get your timing checked make sure your belts are tensioned correctly, maybe get your ignition coils checked if you still got lag.
check out the knowledge base here on ub plenty of information there.
if all else fails take it to a reputable garage or main dealers and get a full diagnostic done .
Old 05-08-2007, 05:21 PM   #3
DBB
thank you for your reply. one other thing, i'm hearing a light knock shifting down or up between gears. sounds like its coming from passenger side rear.
Old 05-08-2007, 05:38 PM   #4
stevo
could be a number of things, you need to get under the car and check all mountings and heat shields also rear trailing arm bushes which i suspect it could be
Old 05-08-2007, 06:16 PM   #5
theSMELSINATOR
theSMELSINATOR's Avatar
Your Ride: 1990 325iX
try getting a chip for it, too. that helps remove any lag in the RPMs. i hear good things about EAT chips, but you'll have to see if they make one for your car.
Old 05-08-2007, 06:26 PM   #6
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 125 / 340
Your Ride: ^^
I am experiencing the rear thumping noise also. It is a bushing more then likely. might be a subframe bushing.
tell if you find out.
also, check your hoses again, they may look fine, but twist them a little to check if they only look fine. I know my vacuum hoses looked fine, but under closer inspection they were holy. (not the religious type.)
Old 05-09-2007, 11:36 PM   #7
1985 325E
1985 325E's Avatar
Your Ride: 1985 325 E
Question
Is there a specific area in this forum that has a "library" of this knowledge base you refer to? I have several electrical issues, and have been searching and searching, but have not been able to find anything. I would LOVE to try and find a complete wiring diagram for my 325E.
Old 05-09-2007, 11:43 PM   #8
Rate My Car: 84 / 340
Old 05-10-2007, 08:32 AM   #9
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 130 / 340
http://www.unitedbimmer.com/forums/129019-post2.html
try downloading that haynes manual. it has electrical/wiring diagrams.
Old 05-10-2007, 11:22 PM   #10
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Check your rear bushings. That happened to me on my last E30. and it was NOT fun to change. If you can put it on a lift and push up on it with little effort, get ready to do some wrenching. Good luck.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Clicking sound during acceleration mrkbik E36 18 11-16-2007 10:13 PM
FWD vs RWD komodo United Off Topic  **FOR MEMBERS ONLY** 35 07-14-2005 10:18 AM
